GM ASA Cam
Old Jul 19, 2007 | 12:24 PM
TransAm Mania's Avatar
Just understand that the ASA cam is still really mild. Personally, I'd go carbed and run something around 235-238 duration and 600+ lift for an old TA. Gotta have the rumpity sound for old school cars IMHO!
I hear that but I've gotta consider drivability and such. Its not going to be a daily driver or anything but I would like to drive it a lot during the summer and whenever the weather is good. I would say I'm trying to keep it a bit on the mild side, the high end of mild if you will.
Old Jul 19, 2007 | 09:51 PM
dirt track racer 81's Avatar
Originally Posted by m8w6r77
whould this cam be too big for the lq4. since c/r are different from the lq9 and lq4.
this is a baby cam with a lot of thump..i have a cam bigger than this in my lq4 that i tow 12,000 lbs with with no problem..
Old Jul 20, 2007 | 07:37 PM
SS_bnoon_SS's Avatar
That's just it, the ASA cam is still on the baby side. Go with something in the same duration/etc but in a higher lift. Somewhere around 560-570 is still considered mild for these engines.
Old Jul 21, 2007 | 08:15 AM
m8w6r77's Avatar
what about changing the rockers for 1.8? wouldnt that get you close to the .560. i think it would more .555.
Old Jul 21, 2007 | 09:20 AM
Yogi Bear's Avatar
The 1.8 rockers would not be cost effective. The money would be better spent on an aftermarket cam with less exhaust duration, more lift and a bigger LSA.
Old Jul 22, 2007 | 02:13 AM
Keith's Avatar
Go with the Grand Am cam. 239/251.
Old Jul 22, 2007 | 02:20 AM
RandomHero's Avatar
That's not really true, when the heads begin to max out around .525 of lift. If any of you has ever see a flow chart for some 317 heads then you know that they do flow about 30-40 cfm more than stock 5.3L heads but they max out no more than .525 lift. Basically, you won't be gaining any horsepower out of going with a higher lift cam because your heads are maxed out.
So essentially duration and lobe grind are the two main factors you should consider when you buy a cam. This is just from a scientific standpoint.
Oh, and then when you get new heads, the truck intake maxes out pretty quick too. It's a never ending cycle.
Old Jul 22, 2007 | 07:16 AM
ramdaspadhye's Avatar
If he were to run the cam in a truck, he'd need the wider lobe separation, but since it's going into a car the narrow separation will allow more peak HP and be better for his application.
I don't believe that's entirely true. The lower LSA will bring the torque in sooner than a higher LSA, which is why boosted motors need a larger LSA (115+) than a lower LSA (110-114) and so that it'll pull more vacuum.
Old Jul 22, 2007 | 12:25 PM
m8w6r77's Avatar
so around about guess for 6.0 lq4. what would i expect for power wise with just changing to one of these cams. with 317 heads. hotcam? asa? grand am? so stock hp 300hp 360ft lbs.
Old Jul 22, 2007 | 04:48 PM
Personally, I'd go with something along the range of 220ish, not much larger than that if you're gonna keep the stock TC...
If you upgrade your stall to like a 3000 stall, or 3200 stall, then go for something around the 230ish range. Get a custom ground comp cam like this...
228/234 .571/.576 on 112lsa
That should get you moving quite well... And check out WCCH... they can hook you up with a nice set of ported 6.0 heads that will make it breath quite nicely!
