Gear Change w/ Predator
Old Sep 30, 2003 | 02:24 PM
1TRUESS's Avatar
Default Gear Change w/ Predator
I think I have read that poeple are having trouble with the Predator not being able to change for the new gears. Has this been fixed? If mine does not work what should I do? 3.73 to a 4.10!
Old Sep 30, 2003 | 03:13 PM
ArticGMC's Avatar
Default Re: Gear Change w/ Predator
It will not be fixed until the next firmware update. If changing the tire settings doesn't set the speedo right then you will need to get a custom tune. I went from 3.42's to 3.73's with larger tire than stock. I had to get a custom tune because changing the tire sizes like they said caused my abs and brake light to come on when driving.
Lar
Old Sep 30, 2003 | 03:20 PM
1TRUESS's Avatar
I had 255 70 16 and went to 285 50 18. I changed the tire size and the predator took it. I just went out a change the gear setting to 4.10s, even though I don't have them yet, and it took that too. But I did not feel a difference in both of them?! Is this what every one is talking about? Should I feel a shift point change?
Old Sep 30, 2003 | 03:34 PM
gonzo 6.2's Avatar
All i can say is great job.nice Et's and great MPH for the mods.IMHO,you could spend your money else were for a better gain.Nothing wrong with 3.73 in a light truck.Lotsofun runs bone stock with 3.42s runs 14.8
Old Sep 30, 2003 | 06:23 PM
goshawk23's Avatar
Truck addict
02silverado, you have mail.
Old Sep 30, 2003 | 07:42 PM
1TRUESS's Avatar
goshawk23 got your mail!
The reason for the diff and gear change is, I found a lot of shavings last gear lube change about a CD size circle around the magnet. The gears look fine, but my G80 sucks now. It is very unpredictable. Also it is making clucking noises in and out of park. I will come to a light and it feels like I've been rear ended. The truck will feel like it squats and chunks! So I am replacing every thing. Getting a good deal, $100 for the gears $500 for the diff and install kit plus overnight shipping. and $200 for install. I was quoted at $1200! I think I could not pass this up. Since a bunch of us guys here in Columbus rented out a track, Oct. 17, unlimited runs all day!! I it is about 2 hours away and a roll back would cost me big bucks if my rear went out up there.
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
thunder550
Oct 8, 2015 04:53 PM
Noah Burns
Oct 5, 2015 06:46 AM
Dezert1500
Jul 30, 2015 02:51 PM
