Gauge install progress/pics
#42
Originally Posted by wkdivr
I like that!! What gauges do you have?
Fuel Pressure
Boost
AFR (Wideband)
EGT
I have to say wiring is very tedious
all for a very good cause though
#43
Originally Posted by moregrip
need some help:
I need a 12v source that comes on when the ignition is in the "ON" position, but does not turn off when the truck is started and was wondering what that source typically is. I have all the wiring/connector diagrams for my truck, so I really just need the typical source or sources so that I don't cause any problems, also, any upgrades that might be needed like a slightly larger fuse or whatever.
On another note...does anyone make pod/bezels like that for G-Tech Pro meters? Something that would allow you to keep it there permanently, but still be able to pop the meter out to use it in other cars and download info into your computer?
#45
Tach
Fuel Pressure
Boost
AFR (Wideband)
EGT
Fuel Pressure
Boost
AFR (Wideband)
EGT
What kind did you get for The boost/vac, and fuel pressure?
#48
Originally Posted by Flipper
Those are bad ***!
Well, all thats left is to run 3 lengths of wire down the passenger side for the switches
taking a break today.I ended up taking most of the dash apart to route my wiring harness along a factory harness.
Probably an hour of work left.
#49
Originally Posted by XLR8NSS
Did you test the switches out?
Best Part! the lights on the round rocker switces that indicate "ON" are green just like the digital readout on the Nordskog gauges, woohoo!
hartinclay
Aug 3, 2015 07:03 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
