Truck Throttle Body
One thing that will help you - you can buy a service harness for the 05 SSR throttle body. That will give you the 6 conductor plug and several inches of wire to splice into your existing wire harness.
You are going to have to think through this a little yourself. You know that the 03 has 8 wires and the 05 has 6 wires. The 03s extra two wires are 5v reference and ground. The 05 uses a single ground and 5v reference for the TP sensors.
If it were me, I'd play connect the wires, leave off one ground and one 5v reference for the 03 harness, and see if it works.
PINS for the 05 TB:
A.) ACT2
B.) ACT1
C.) +5v TPS Reference – Common to both TPS’s
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
PINS for the 05 TB:
A.) ACT2
B.) ACT1
D.) TP1 Signal 0-5v
E.) Common Ground
F.) TP2 Signal 5-0v
GreyChevy
07-07-2015 08:57 PM
Gadgetized
07-07-2015 04:40 PM
