Gauge install progress/pics
Old Apr 22, 2005 | 05:48 PM
  #31
O3GMC's Avatar
12 Second Club
good job, clean install as usual
Old Apr 22, 2005 | 06:00 PM
  #32
GoldenVelvet's Avatar
Are those Dynotune gauges?
Old Apr 22, 2005 | 06:07 PM
  #33
moregrip's Avatar
what a rush!
No, they are Nordskog.
Old Apr 22, 2005 | 06:08 PM
  #34
moregrip's Avatar
what a rush!
thanks, appreciate the compliment, btw like the new sig great picture of the radix!
Old Apr 23, 2005 | 06:39 PM
  #35
moregrip's Avatar
what a rush!
need some help:
I need a 12v source that comes on when the ignition is in the "ON" position, but does not turn off when the truck is started and was wondering what that source typically is. I have all the wiring/connector diagrams for my truck, so I really just need the typical source or sources so that I don't cause any problems, also, any upgrades that might be needed like a slightly larger fuse or whatever.
Old Apr 23, 2005 | 07:14 PM
  #36
wkdivr's Avatar
What about the wire that you ran to the intercooler pump/fuel pump?
Old Apr 24, 2005 | 12:06 PM
  #37
moregrip's Avatar
what a rush!
Here are the pics of where and how I mounted the remote senders for the fuel pressure and boost gauges. I used rubber to surround the gauge to insulate them from causing vibration noises and used zip-ties to secure them. The line with the purple tape is the fuel pressure line, the other is the boost.
The braided lines run out of the stock openings on the back of the fuse box cover. I used permatex high temp pipe sealant on all the NPT threads. enjoy!
Old Apr 24, 2005 | 12:11 PM
  #38
BlownChevy's Avatar
blownerator
25 Year Member
good idea, I have not seen that before
Old Apr 24, 2005 | 12:19 PM
  #39
Green Thunder's Avatar
Originally Posted by moregrip
Here are the pics of where and how I mounted the remote senders for the fuel pressure and boost gauges. I used rubber to surround the gauge to insulate from causing vibration noieses and used zip-ties to secure them. The line with the purple tape is the fuel pressure line, the other is the boost.
You're doing a helluva job there Grippy!
Old Apr 24, 2005 | 12:38 PM
  #40
moregrip's Avatar
what a rush!
thanks bro, I'd really like some thin metal spiral clamps, but the zip ties will do for now and they give me a little bit of movement when re-installing the cover
