gains with 90mm lingenfelter vs. truck intake?
Old Jun 12, 2011 | 11:26 AM
bighoss77's Avatar
Default gains with 90mm lingenfelter vs. truck intake?
found a 90mm ported lingenfelter intake manifold and wondering if this is a worthwhile upgrade to a 2001 silv. 2500hd with the lq4? i read alot that the truck intake flows better than car intakes, wondering if there would be a worthwhile gain in performance in running this over the truck intake?
http://atlanta.craigslist.org/atl/pts/2411207961.html
Old Jun 13, 2011 | 11:56 AM
bighoss77's Avatar
anyone know if the truck intakes flow better than aftermarket car intakes?
Old Jun 13, 2011 | 12:15 PM
Mangled03gmc's Avatar
Baltimore Whore
With that intake you will more then likely need to change the alternator location, also will need diff fuel rails, use f body injectors, diff injector plugs.. If your looking for a upgrade, look into a 08 up truck intake or TBSS intake.. They use a 90mm tb( you will have to by a Dr X harness to use a 90 mm tb or you can buy a 70$ adapter to run the standard 78mm tb.. You can use the truck injectors, but will have to mod the fuel rails to work.. Do a search for tbss intake...
Old Jun 13, 2011 | 12:41 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
01 is cable no drx harness needed
Old Jun 13, 2011 | 01:22 PM
bigboy576103's Avatar
I agree, go with the 08 truck intake and buy a cheap 90mm tb and your good to go.. keeep an eye out on classifieds theres usually one flowting around.
Old Jun 13, 2011 | 01:23 PM
https://www.performancetrucks.net/fo...d.php?t=483869
Old Jun 13, 2011 | 05:04 PM
AndysC3's Avatar
have a look through these. They will answer pretty much all of your questions. I use the vette fuel filter to convert my return lines to the returnless fuel rails. Has way better throttle response and it'll pin you to your seat from 4k rpms up,
https://www.performancetrucks.net/fo...ht=tbss+intake
https://www.performancetrucks.net/fo...d.php?t=459296
Old Jun 13, 2011 | 05:17 PM
Baltimore Whore
Yep, I totally overlooked the year..
Old Jun 14, 2011 | 08:32 PM
bighoss77's Avatar
well, i have a vortech v-2 charger sitting in the garage im still gathering random parts to complete it like oil lines, fuel press. regulator, and other odds and ends... so i thought going with an aluminum intake would be a little boost freindly... ill look into a '08+ or a TBSS intake
TA63
Mar 29, 2016 04:38 PM
wrb002
Aug 31, 2015 12:00 PM
Slammed96
Jul 27, 2015 07:22 AM
black6spdz
Jul 16, 2015 01:32 AM
jrplz
Jul 9, 2015 12:07 AM
