Future LQ9 mods?
Old Jun 23, 2008 | 07:44 PM
GMCtrk's Avatar
Default Future LQ9 mods?
I'm looking forward now to future LQ9 mods.
I was thinking about stock LS6 heads and a cam. I want a cam that makes a lot of torque where I drive between 1000 and 3000 rpm. I rarely go above that. Yet I still want a cam that's going to give a better top end than stock if I do decide to get on it. As far as the stall goes, I was thinking about keeping it stock or maybe a trailblazer stall. Your input is greatly appreciated.
Old Jun 23, 2008 | 08:01 PM
Rafedial's Avatar
The LS6 #243 heads will raise compression to roughly 11:1. Along with Low lift/low duration cam like the LS6 cam would work well. Custom tune, Heads/Cam P-T-V clearance, 93+ fuel all critical to this combo.
I currently have a Trailblazer I6 TC and for your first converter is a great choice . As far as drivability goes I wouldn't change anything on the truck if you don't spin much over 3K. Mods are only worth it if you use it.
Old Jun 23, 2008 | 08:06 PM
GMCtrk's Avatar
So you say the only thing I should change is to add a TB TC and be done with it? What if I did LS6 heads and a TB TC?
Old Jun 23, 2008 | 08:10 PM
Rafedial's Avatar
I'm sayin go for it all....and a set of injectors
Old Jun 23, 2008 | 08:13 PM
GMCtrk's Avatar
LOL, there is a budget I guess. As far as exhaust goes, all I plan on doing is having a Flo Pro muffler welded in.
If all I did was a trailblazer TC, what kind of gains would I see in the butt meter?
Old Jun 23, 2008 | 08:22 PM
Rafedial's Avatar
maybe 3-4 tenths in the quarter depending on weight of truck. Still requires tuning and some hours removing trans. If you are 2WD a Trailblazer stall would be easy. Go with the cam first IMO.
Old Jun 23, 2008 | 08:24 PM
GMCtrk's Avatar
I think I'll do a cam and the TB stall. Could you recommend me a cam that would work well with the TB stall and have a prominent low end? Thanks for your help
Old Jun 23, 2008 | 08:33 PM
Rafedial's Avatar
what are the current specs of your truck?
Old Jun 23, 2008 | 08:38 PM
Rafedial's Avatar
LS6 Camshaft
204/218 duration
.551/.547
117 LSA smooth idle
Requires 2002+ LS6 valve springs, good low end power
I may be wrong but the LS6/Z06 Cam has a 0.050 smaller base circle on the cam, requiring longer pushrods. The are many other low lift/low duration cams out there, look around at the sponsors here. LS6 Cam and springs could be had for 350-400, or maybe cheaper.
Old Jun 23, 2008 | 08:41 PM
GMCtrk's Avatar
stock LQ9, stock 4l60, 3.42 rear end. 2wd ecsb.
