Forged crank vs stock crank
Old Oct 27, 2015 | 12:48 PM
  #31
Atomic's Avatar
I have a gauge for that
A bad balance job on the rotating assembly is also very hard on the bearings and might show up as crank flex.
Old Oct 27, 2015 | 02:02 PM
  #32
smokeshow's Avatar
Mod with training wheels
Any force sufficient to strain a metal will bend it. Not too complicated.
Old Oct 27, 2015 | 03:23 PM
  #33
Gadgetized's Avatar
Originally Posted by AkSSS
And without dropping the pan and the caps, there is no way to check for this? Correct? Or just don't worry about it until you see other problems? Windows and stuff.
I would think you could degree the #1 cylinder vs #8 cylinder and they should be 90 degrees apart. Anything off would indicate the crank is bent. I have never done this, but if it were bent I could only assume this number would be off.
Old Oct 27, 2015 | 03:58 PM
  #34
Atomic's Avatar
To really see if it is bent you will need to remove the crank and measure the runout on the journals. Here is mine when I bent it,
Old Oct 27, 2015 | 05:11 PM
  #35
Gadgetized's Avatar
When I got my Eagle crank there was paperwork in the box that said .002 was acceptable(I will see if i can find the paper). I checked it and it was at .001. I spoke to my machine shop about it, and he said half of the oil clearance is acceptable. I checked my LY6 I am building and it was also .001. That engine had 90K on it and completely stock, never even had a tune in it.
Old Oct 27, 2015 | 06:02 PM
  #36
MikeGyver's Avatar
Originally Posted by Atomic
...Ended up having 0.020" runout on journal #2 I think.
That must be a typo:
... Here is mine when I bent it," Main Journal Runout - YouTube"
Yeah, the vid shows .002-.0025, not .020. Happy to point out people's mistakes.
Old Oct 27, 2015 | 07:16 PM
  #37
George C....'s Avatar
Formerly ScreamingL
Well, so far I have cut every filter open. I only have some metal at the first startup oil change and the 100 mile oil change. I did another one at 100 miles and one at 1000 miles and there was nothing in it. I even screened the oil as it drained. Hopefully I'm good.
I don't see myself making enough power to flex the crank. I can only hope so.
Drew was telling me about your build
Old Oct 27, 2015 | 07:45 PM
  #38
Atomic's Avatar
Yea I forgot a zero haha, I saw 0.0040 though.
Heres the limits:
Crankshaft Main Journal Out-of-Round - Production 0.003 mm 0.000118 in
Crankshaft Main Journal Out-of-Round - Service Limit 0.008 mm 0.0003 in
So clearly its no good
Old Oct 28, 2015 | 01:06 AM
  #39
AkSSS's Avatar
Lol. He ratted me out! Drew has done a lot for my family. Would do anything for him.
As atomic has said, everyone is building a 408 s480/80e combo. I'm just another one. Not much for this kinda stuff up here though. I had to do everything myself. Learned a lot off of here. I do love making some cars look bad.
Old Oct 28, 2015 | 09:33 AM
  #40
Formerly ScreamingL
Was telling me how wasnt any faster then prior, I flew up there in 2012 to tune his camaro...He talked about flying me up there if he goes 402 in camaro
