Forged crank vs stock crank
Old Oct 22, 2015 | 08:33 PM
2000silvrx81's Avatar
Default Forged crank vs stock crank
I'm in the middle of a 370 build and wanted to question what crank to run. I've ran a forged crank in all of my drag car motors, but am not really looking to break land speed records by any means with my 370. How many people do h beam rod, forged piston motors with stock cranks? Are there normally issues with a stock crank?
Old Oct 22, 2015 | 09:50 PM
EscaTruck's Avatar
stock crank is good for 1000 hp... if you supercharge.. i suggest a forged crank... just make sure you dont knock... stock is fine prolly...
Old Oct 23, 2015 | 12:01 AM
Vortec350ss's Avatar
Stock cranks are used in combos like that all the time. What do you plan to use the motor for, how much power do you want to make, and how will you make it?
Old Oct 23, 2015 | 12:57 AM
Blown06's Avatar
8 Second Truck Club
You've broken one over 1000?
Old Oct 23, 2015 | 05:51 AM
02singleturbo's Avatar
I have seen stock cranks take 1500 hp an not fail
Old Oct 23, 2015 | 07:49 AM
I'm looking to make somewhere between 430 and 450 to the ground. Callies Rods, Diamond Flat Tops, 235 TFS heads, Fab Intake, 102 tb. I want it to be a fun, dependable truck I can drive 200 miles if I wanted. It will only be driven on weekends, but I like to take a hot rodding trip every now and then.
Old Oct 23, 2015 | 08:05 AM
Stock crank will do what you want it to in its sleep...
Old Oct 23, 2015 | 08:32 AM
George C....'s Avatar
Formerly ScreamingL
Stock cranks flex at 1000rwhp.....youll see oil psi drop some after it has flexed
For mild builds stock crank ftw
Big pulley blower setups over 1000 id go forged
Old Oct 23, 2015 | 08:48 AM
smokeshow's Avatar
Mod with training wheels
Do you mean to say that the oil pressure drop is permanent after the crank flexes, or just while it is flexing?
Old Oct 23, 2015 | 09:23 AM
Formerly ScreamingL
A sign of crank flexing is a drop in oil pressure..typically 5-10 psi lower at operating temp, following this youll see material in the oil
I saw this on the ly6, and quite a few threads on yellowbullet and ls1tech....
Motor still ran just had less oil pressure
