FLP 5 issues
Old May 16, 2005 | 06:01 PM
  #41
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Originally Posted by Weedo
And the PI is $900 roughly so about $2900. Not too bad. What are you on now, your 3rd one?
In fairness to Chuck, I went into this knowing my setup was an R&D project and we're still working out the kinks at this level. The first one was installed incorrectly (we think) and the second one had a little problem with a silly plastic part (check valve) -- I would've had the same problems the first time, but the second one was a new part we tried to help handle the boost I'm cranking out -- didn't work out, but it's all good in my book. Neither of them broke hard parts and Chuck took care of them all on his dime. I'll take that kind of customer service any day of the week. Show me anyone that can build a tranny to hold this kind of power and WARRANTY it... Chuck does both at lighter weights and I'm willing to bet will be one of the few who do it at 5400lbs.
2bseen is putting down big power with a couple of n2o shots (one of 'em is a 200shot I believe) on an FLP L5 and has no troubles.
I'm not gonna open my mouth about power, torque and the third one (jinxing everything) but I will say I fixed my cut-out today, which might give you an idea of how priorities have changed
Old May 16, 2005 | 06:04 PM
  #42
Kano's Avatar
Originally Posted by chopperbrent
Sorry to hear about the tranny Billy , to spend that kinda money on a built tranny and have it go boom allready . Man i wouldnt be happy at all !!!
The Yank TT3000 came in today .
you know
**** happens
I dont know what happened
but Ill be back rollin soon
this is why I went with the FLP
I knew if it broke, it would get fixed right away
and get great CS also
which is in the process now
alot of "big" names on here referred me to him
because of the outstanding service they got
as well as the product
even though it broke Im still satisfied with the decision I made
because Im sure it will be fixed
glad you got the yank
youre gonna love it
I did
thanks Brent
  #43
Weedo's Avatar
I have a warranty, and they're fixing it for free, but I'm not sure how much power I'm allowed to make to have the trans handle it. We'll see...
Now come on, tell us what kind of power you're making!!
Old May 16, 2005 | 06:10 PM
  #44
I AM A MOTHERF*CKER
I'll go this far:
It's gone beyond 'stupid-fast' on the street and has entered the 'scary-fast' realm - SOTP it feels like low 12's/high 11's in low boost (8psi) without meth, and a base street tune. It also feels like there's a lot left in the tune.
Changing into a new cam this weekend, and then it should be all tuning for power and tire smoke ( and maybe a little surprise )
Old May 16, 2005 | 07:44 PM
  #45
2bseen's Avatar
11 Second Truck Club
I have had good luck with my fl5 so far. I have about 2500 miles on it with 10 strip passes on 125 shot and a built 408ci motor. I will be going up to a 200 shot in the next week or 2 and installing a fast 90 intake and ssr t.b. also. I am not saying that I wouldn't consider a 80 but they don't built one for a awd yet.
Old May 17, 2005 | 10:31 AM
  #46
gonzo 6.2's Avatar
I'll go this far:
What cam specs?
Old May 17, 2005 | 11:02 AM
  #47
FLP
LS1TECH Sponsor
Originally Posted by gamedawgx53
I talked to Chuck this evening
Hes gonna start workin on the one that came out the truck "core"
monday as soon as it arrives
He'll take care of me ...no doubt in my mind
chucks a good guy
finally got her out
man Im getting good at this
I think it broke a hard part
if you look down the input shaft
you can see chunks of metal about the
size of a pencil eraser rolling around
behind the front seal
I gotta send the vig off too
to get cleaned out
might have em up the stall a little also
the PI is tight compared to the yank 3000
Not to mention it didnt fit right
I had to space it with washers
IMO You shouldnt have to do that on such an expensive
TC
Well, By what you saw here I would have to say that the pump has broken lugs, thus why you have no gears. Now we have to find out why you had to use washers to space the converter?? I already have a call into PI and they are waiting for the converter to get there so they can check the build height.
I'm sure they will correct anything if there was a mistake and usually they will help me with any trans repairs if it was there fault. You should never have to use washers with one of these converters, IMO at least from my experience.
I'm sure will find out soon what happened here when I get the trans back and I here from PI. Until then will get you back on the road ASAP.
Chuck
Old May 17, 2005 | 11:10 AM
  #48
gonzo 6.2's Avatar
Seems the trans builders and the converter builders would send along with there products some sort of basic gauge for the novis installer to get the converter properly seated.
Old May 17, 2005 | 11:49 AM
  #49
Weedo's Avatar
I'll go this far:
That's ridiculous..........and I LOVE it!!!! Can't wait to hear more!!!
Old May 17, 2005 | 11:53 AM
  #50
I AM A MOTHERF*CKER
Originally Posted by gonzo 6.0
What cam specs?
Plan one is 236/230 a little more lift and a tighter lsa (Rick Squires' cam from his 396) -- basically the same cam, but a reverse split and less overlap. Plan two... depends a lot on what Joe Vinci tells me later this afternoon
