FLP 5 issues
#51
thanks Chuck
I really doubt it was the tranny also
It just acted so good as far as the shifts and
how smooth and quiet everything was
I wasnt trying to slander FLP or the quality of
your product with this post
more so trying to see if this had happened to anyone else
especially the washer deal
that one threw me
Ive never had to do that on any vehicle Ive worked on
or read about it
until I looked through the PI directions
with bellhousing mounted to block
if you have a gap greater than 1/8 between tc and flexplate and you didnt use
the washers
It seems like you run the risk of not being fully engaged in the front pump
thats why I used them
I also have the tracking # on the verter if that'll help any
it should arrive 5/18
I really appreciate the great customer service you're providing
and being there when I call or getting back to me in no time.
product quality usually follows the same path as CS
from what Ive experienced
Im sure once we get this all straightened out everything will be fine
thanks again Chuck
Billy
that one threw me
or read about it
the washers
thanks again Chuck
Billy
#52
Originally Posted by FLP
Well, By what you saw here I would have to say that the pump has broken lugs, thus why you have no gears. Now we have to find out why you had to use washers to space the converter?? I already have a call into PI and they are waiting for the converter to get there so they can check the build height.
I'm sure they will correct anything if there was a mistake and usually they will help me with any trans repairs if it was there fault. You should never have to use washers with one of these converters, IMO at least from my experience.
I'm sure will find out soon what happened here when I get the trans back and I here from PI. Until then will get you back on the road ASAP.
Chuck
Chuck
For what it's worth, my recent FLT install with PI converter lined up perfectly without washers. My problem was the opposite. When I installed the trans, the torque converter was snug gainst the flywheel and would not budge. Turns out I didn't have the converter completely installed properly on the trans. Chuck said to spin and listen for the 3 clicks. Despite hearing it straight from Chuck, I tried to install it with only 2 clicks (not knowing obviously) and it just plain won't work that way.
Keep us posted on what you find.
#53
Chuck
Chuck
i agree with the spacers chuck. if i have to put spacers in for the torque converter, it's going back. that can kill a pump in a hurry.
Zippy
murderedSS
27
Oct 12, 2015 11:13 AM
TAPyvehc93
Sep 14, 2015 01:22 PM
