Finally got the Headders
Old May 25, 2006 | 12:19 AM
blksilverado's Avatar
I used pb blaster and had no problems. I was careful taking them off. didn't crank on them real hard. I'm thinking of getting new bolts tho, looks like crap with the rusted bolts and shiney headers. By the way i put on Pacesetters. working on the rest of the exhaust right now
Old May 25, 2006 | 01:25 AM
Nasty73z's Avatar
It helps to use PB Blaster because as the bolts age and rust, they become very brittle. So when you start to torque on said bolt that is tight, it will break right off. By spraying them first you can help lubricate the treads and make them come out easier with less chance of breaking one.
Old May 25, 2006 | 08:56 AM
EvilChevy's Avatar
Originally Posted by agreif
Everyone talks about breaking the bolts in the heads. Two questions
1. Would spraying the hell out of em with PB help this at all?
2. How did you get the bolts out after you broke em off in there?
My buddy and i had to extract them from the haed by drilling them out an PB helps a lot. And Use New Bolts age and heat make the stock bolts too brittle.. Also it's a good idea to get new nuts for the ORY where it connects to the rest of the exhaust.. Oh yea start it up open headder for a couple of seconds it sounds mean
Old May 25, 2006 | 02:52 PM
hog's Avatar
hog
Make sure the engine is STONE COLD as any heat in the engine will make the bolts more prone to breakage as the heads are aluminum.
peace
Hog
Old May 25, 2006 | 04:08 PM
Full_Pull6.0HD's Avatar
I had to replace a few broken manifold bolts. Using a brand new pair of vice grips, it only takes an hour or so for each bolt turning it 15 degrees at a time.
Old May 25, 2006 | 04:26 PM
sv650lex's Avatar
I recommend new header bolts. I got mine from summit racing they have a special washer and c clip that go on the head of the bolt after it is installed. They are tear drop shaped and touch the header pipes so they can never loosen up. I've had mine on for a year without retorking them.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
Velocity1
Oct 2, 2015 08:01 AM
Lthompson
Oct 2, 2015 12:45 AM
