Finally got the Headders
I used pb blaster and had no problems. I was careful taking them off. didn't crank on them real hard. I'm thinking of getting new bolts tho, looks like crap with the rusted bolts and shiney headers. By the way i put on Pacesetters. working on the rest of the exhaust right now
It helps to use PB Blaster because as the bolts age and rust, they become very brittle. So when you start to torque on said bolt that is tight, it will break right off. By spraying them first you can help lubricate the treads and make them come out easier with less chance of breaking one.
Originally Posted by agreif
Everyone talks about breaking the bolts in the heads. Two questions
1. Would spraying the hell out of em with PB help this at all?
2. How did you get the bolts out after you broke em off in there?
I recommend new header bolts. I got mine from summit racing they have a special washer and c clip that go on the head of the bolt after it is installed. They are tear drop shaped and touch the header pipes so they can never loosen up. I've had mine on for a year without retorking them.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
