A few random pics, intercooler, homemade CAI, wideband installation, 90mm TB, etc
Old May 23, 2006 | 07:58 PM
thunder550's Avatar
High on diesel fumes
Default A few random pics, intercooler, homemade CAI, wideband installation, 90mm TB, etc
Took some new pics today, just a few random shots, though I'd share.
New heat exchanger, bought from BlownChevy, made my own mounting brackets for the top, zip-tied it to the bottom. I LOOOOOVE zip-ties. Running inline with the original Radix HX. Peak IAT's are still high, but it recovers a lot faster.
My home-made CAI. Bought the AirAid filter and dam from another member, bought the PVC and flex-PVC connections from Home Depot. Total cost $65.
Side view of the Nick Williams 90mm TB. Had to enlarge the bottom two mounting holes a little bit, and grind out the inlet of the Radix, but it was pretty starightforward to install. Still haven't found the right clip to make the cruise control work, may try to figure something else out....
Tranny line extensions - I need to redo these, for obvious reasons.....
Also had to grind off the outermost ear on the tranny case to clear the ASM headers. I was freaking out cause I didn't think they were gonna fit....
DynoTune Nitrous digital WB gauge, installed in stock cluster....
Innovate LC-1 controller, zip-tied to fuel lines. O2 sensor is in the rear driver's side O2 bung on the stock y-pipe.
Here's how I did the connections for the EFILive interface - took a mono mini-jack and cut it up, very simple to plug and unplug, works well. Also you can see in the background I got a mounting plate from Checker to put in a momentary switch forO2 sensor calibration, and the status LED is mounted there as well.
Old May 23, 2006 | 10:39 PM
kbracing96's Avatar
Is that tranny cooler line still touching the header??? That could be what is causing your higher tranny temps. Everything else looks goodfor a white guy
Old May 24, 2006 | 11:09 AM
thunder550's Avatar
Yep they are touching. I tried to zip-tie them out of the way but apparently the zip tie couldn't take the heat cause it's gone now. I need to re-route them, still have plenty of braided hose left. I bet my fluid is burnt already too
Old May 24, 2006 | 03:10 PM
DakotaKiller5.3's Avatar
how was that gauge install?? i want to do this with a trans gauge... PITA??
Old May 24, 2006 | 05:56 PM
ZR1 DREAMING's Avatar
nice progress, I like the wideband gauge install... clean and stock looking.
Old May 24, 2006 | 06:03 PM
TIM Z's Avatar
11 sec. Truck Mod
that wideband install is superb!!! nice work, im impressed. did you just use a 2-1/16 hole saw ?
Old May 24, 2006 | 06:21 PM
thunder550's Avatar
Yep, had to do a little bit of manual work with a dremel but it was pretty straightforward....BTW Kyle, you left your hole saw laying on my workbench.
Old May 24, 2006 | 06:59 PM
kbracing96's Avatar
Damn! I knew I for got something . You can just paypal me 20 bucks for it
BTW, I though your idea of cruise control was setting a brick on the gas pedal:jest
Old May 25, 2006 | 08:49 AM
budhayes3's Avatar
PT's Slowest Truck
Nice, clean job Thunder, keep up the good work
chacho44
Aug 17, 2015 03:36 AM
Three6GMC
Aug 3, 2015 07:53 PM
zblee
Aug 3, 2015 03:45 AM
03sierraslt
Jul 11, 2015 02:47 PM
