FAST intake manifold
Old Jun 4, 2007 | 03:03 PM
ridndirty's Avatar
Default FAST intake manifold
has anyone heard of the FAST ls6 intake manifold? heres a linkhttp://www.popularhotrodding.com/tech/phr_0309_fast_ls1_intake_manifold/
i want to know if itll work on the 4.8? that would be insane
Old Jun 4, 2007 | 03:58 PM
whitesilvy04's Avatar
yeah, i was looking at that awhile back for my truck..
It will bolt on but i think you need to swap your electronically driven throttle body to a cable driven throttle body and i think you need to change water pumps too..If i'm correct. I could be wrong.
Old Jun 4, 2007 | 04:03 PM
silver-mod-o's Avatar
Hunt&Fisherator
do a search for 'LS6 intake swap'... this has been addressed sevral times, in a nutshell though, you have to go to F-body front accessories and fuel rails... along with other goodies.
Old Jun 4, 2007 | 05:31 PM
joshluther's Avatar
You can run truck acc. but you have to move stuff around. You can run the Electronic TB with it also. Here's my l76 setup I made, same idea. I have made this for a few members here.
Old Jun 4, 2007 | 05:57 PM
dropkick13's Avatar
what are the gains with the ls6 intake?
Old Jun 4, 2007 | 06:15 PM
joshluther's Avatar
Originally Posted by silver-mod-o
do a search for 'LS6 intake swap'... this has been addressed sevral times"
What he said
Old Jun 4, 2007 | 06:51 PM
nightrunner's Avatar
Mr. Obvious
IMO that is waaaay too much intake for a 4.8, ls6 would be plenty, that is more suited for a wild 6.0L and up you dont really need a $1k intake manifold on a 4.8
as a note to those that are going to say you will loose all your lowend with a fast 90 IF you get it ported, like by Tony Mamo @ AFR, you wont have a loss of lowend, there are graphs to prove this on tech, but im not going to search for them, a normal fst 90mm has some loss but when ported by AFR they seem to gain in the lowend, dont ask me how...
Old Jun 4, 2007 | 08:01 PM
.T.'s Avatar
.T.
Being one of those who says it...
It's the sum of the TB, intake, cam, heads, displacement, CR = power/torque.
A ported 90/90 402 w/worked AFR 205's and a small cam can put out SICK power and torque, NA, running on pump gas. Yes, it's been documented by wise builders who don't throw the biggest of everything they can find into their motor and cross their fingers that it'll put out gobs of power.
BUT
A stock 4.8 would choke and with that intake. Forget tuning it; it wouldn't idle.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
