Exhaust true duel x pipe
Is true dual x pipe on 5.3 good or bad what your opinion, I bought the speed engineering exhaust but the muffler is ******* heavy! I had off road y pipe and borla muffler with turn down, my track time just seem as it wasn’t mph’ing like it should! Crammed 5.3 bolt on, on spray 200+
It shock the **** out of me I promise you that! And that was on stock 78mm tb with tbss intake and off road y pipe and stock intermediate pipe with borla muffler, it has ls3 tb with tbss intake speed engineering x pipe, I just ran it on the street on motor with the 250 tune on the dragy ran 8.78 😎
I really don't think the weight could have made a big difference. I can tell the difference between half a tank when I drive, but that's about 130 pounds, and you shouldn't have picked up more than 50 or 60 pounds. I could only guess that's on the high side.
I bought a speed engineering set of short tubes because of how cheap they were. When I got em, the flange was uneven, and they were so light, I swear they might be 20gauge steel, when EVERY other pair is 16 or at least 18g. That speed engineering stuff is about as cheap as it gets.
I think it was on roadkill they showed two different thrush mufflers that had the exact same exhaust body, and all they do is weld on different size pipes on the end to make 2.5", and 3" mufflers. They both had the same ID on the tubing to housing. I wouldn't put it past speed engineering to be the same way. Dual 3" should be much bigger than what you need. If it's not all welded up, you might want to measure the actual ID of the inlet and exhaust on that muffler. You might be choking it now after "going bigger".
