Engine woes or fueling issues?
Old Nov 9, 2022 | 08:11 PM
  #161
shakenfake's Avatar
Shlumpt
5 Year Member
Here is my log with the timing pulled. I pulled exactly where you said, seems like the knock is still present albeit in a different location than where we talked about. Going to pull four more degrees up to 2600 and see what happens. If nothing then I will add octane booster
Okay knock is definitely false knock in terms of spark. It is every time I step on the pedal instead 8 degrees so I am moving on from that. I will try the octane booster real quick but I do not believe this to be an issue.
Old Nov 9, 2022 | 09:26 PM
  #162
shakenfake's Avatar
Shlumpt
5 Year Member
This is after octane booster. WTF
I am driving exactly as I was previously. No way, there is no way that I got the equivalent of water out of a 93 pump and it caused me to have these massive issues.
Old Nov 9, 2022 | 11:54 PM
  #163
1FastBrick's Avatar
Custm2500's Rude Friend
I Peed in your gas tank....
#sorrynotsorry
Old Nov 10, 2022 | 07:54 AM
  #164
shakenfake's Avatar
Shlumpt
5 Year Member
@1FastBrick
I'm not sure your ***** could reach far enough down to open the hole up. Must've used a funnel
Old Nov 10, 2022 | 10:32 AM
  #165
just_curious's Avatar
Throw this hunk of junk in the gutter and go buy another. JK
You've had a heck of a time it seems like though.
Old Nov 10, 2022 | 10:34 AM
  #166
shakenfake's Avatar
Shlumpt
5 Year Member
I can't say I haven't considered it
Old Nov 10, 2022 | 11:01 AM
  #167
Have you driven an extended distance in a while other than playing around with the tunes?
It runs fine (safely) right? just kinda smokes and sounds rough?
throw some octane booster in it and get out and take it for a 30min drive running it in different rpms fast slow ect. Could even drain tank and refill with "good" gas... well hopefully good.
Old Nov 10, 2022 | 11:11 AM
  #168
shakenfake's Avatar
Shlumpt
5 Year Member
Extended distance meaning how far? My answer is no. I did a 12 mile loop but that is it. I have not tried to drive to work, 13 miles, and back yet or farther.
Yes, yes, no. Sounds perfect.
I added a whole can of race gas concentrate last night which is when the knock went away. I may revert it to the original tune file and then go on a drive. I plan on adding some of the STP Gas Treatment and I probably will fill up at a gas station with 93 or maybe just let the tank keep running down. Probably have around 20 gallons left.
Old Nov 10, 2022 | 12:08 PM
  #169
I think I would want to take a longer drive than that (2-3x that 12 miles) being its sat a decent amount and try to drain the tank down some before putting in new. You would only be putting what 4 gallons of the good stuff in and once that mixes I doubt it would change it really. old/new 50/50 or 25/75 would be much better to test if thats the problem.
Old Nov 10, 2022 | 01:12 PM
  #170
shakenfake's Avatar
Shlumpt
5 Year Member
Yeah I will just do some laps on that 12 mile circuit tonight. Still tossing in that gas treatment though.
