Engine woes or fueling issues?
Old Oct 2, 2022 | 03:42 PM
  #91
shakenfake's Avatar
Shlumpt
5 Year Member
I also have a fuel pressure regulator and new vacuum hose for it sitting on my desk right now.
It still smokes like a chimney though, no idea what the deal is with that. It is so rich that it burns my eyes lol don't get why the AFR gauge reads it as lean though.
Also my AFR gauge STILL does not reliably work. I am going to change the fuse tap location and see if that does anything. It seems to work when I have something plugged into the OBD2 port sometimes and other times it is broke.
Old Oct 2, 2022 | 04:58 PM
  #92
dantheman1540's Avatar
Ok good the battery didn’t fix it
Old Oct 2, 2022 | 05:46 PM
  #93
shakenfake's Avatar
Shlumpt
5 Year Member
Yeah definitely not. Won’t start first crank and still surges and sputters
Old Oct 3, 2022 | 10:13 AM
  #94
1FastBrick's Avatar
Custm2500's Rude Friend
Any chance you have a spare PCM for this?
Old Oct 3, 2022 | 10:26 AM
  #95
shakenfake's Avatar
Shlumpt
5 Year Member
No chance unfortunately. It is something I have thought about though. Dan wants me to try running it without the O2s though
I have been thinking about a bad PCM, don't know exactly how it could of happened but it would explain the disparity between AFR gauge and O2 sensors.
Old Oct 3, 2022 | 10:35 AM
  #96
1FastBrick's Avatar
It's rare, but some times things like the injector drivers go bad or a circuit within the board shorts out. There really isn't anything you the user has done. It could have been a flaw in the manufacturing process, the seal could have gone bad on the case, or an internal component could have just failed...
Old Oct 3, 2022 | 06:10 PM
  #97
Every time I’m out of ideas on a problem and feel lost, I think it’s a bad ecu. Then I find a loose ground, exposed wire, or bad connection somewhere and it’s fixed.
Old Oct 3, 2022 | 09:22 PM
  #98
1FastBrick's Avatar
Talking
Well are you done yet or still playing with the Dirty D... We know your all about that Black tip now...
  #99
shakenfake's Avatar
Shlumpt
5 Year Member
Literally just opened my laptop to edit the tune file lol
Old Oct 3, 2022 | 09:28 PM
  #100
shakenfake's Avatar
Shlumpt
5 Year Member
So my LTFTs have already been set to disabled, guess that was set up originally. I now have my STFTs set to disabled. So is that it then?
I'm kinda confused on what this might test though since the truck runs in open loop upon start up no? Unless the O2s are demanding fuel and shutting them off might stop the truck from demanding fuel?
Gonna go test it out brb
