Electric Fans
Old Sep 22, 2009 | 11:21 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by 7deuce-ss
anyone got pics on this?
so its a wiring harness and reprogram that he includes?
my trucks fan clutch is going out and i have some 04 escalade electric fans that i want to put in.
my truck is also a 2000 silverado
PCM reprogram is extra from both Blackbear and Nelson, prices listed are just for the harness...
Old Sep 22, 2009 | 12:07 PM
7deuce-ss's Avatar
cool thanks for the help, ill get in contact with one of them!
i know the overdrive pully comes off with a impact wrench put whats
the advantage of having it..?
Old Sep 22, 2009 | 04:14 PM
SilverDog's Avatar
Your fans might not fit your radiator. The radiator on the 2000 Silverado is 28" and if the electric fans are 05+ then it's designed for a 34" radiator (not sure of the fans on a 04 escalade).
Old Sep 22, 2009 | 08:13 PM
7deuce-ss's Avatar
good point! didnt think of that.. guess ill find out soon.. thanks
Old Sep 22, 2009 | 08:46 PM
budhayes3's Avatar
PT's Slowest Truck
Escalade has a 34" radiator, so you'll need that if you want to run those fans. I got my radiator from RadiatorBarn dot com, and you'll need bolts to hold it or the fans in, can't remember the length and pitch though...
Old Sep 22, 2009 | 10:12 PM
xlcooplx's Avatar
the advantage of the smaller pulley is to turn the alternator faster. the factory alternator on your truck is 105 amps while the factory alt for trucks equipped with efans is a 145 amp. the smaller pulley will hopefully help to keep from the fans draining your electrical system at idle...i know the smaller pulley worked great on my 105 amp alt so i threw it on my 145 amp alt when i swapped it in!
SS94S10
Jan 3, 2019 01:57 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
