Electric Fans
Old Apr 7, 2006 | 01:19 PM
  #21
white1's Avatar
As far as mounting, I pulled the stock shroud off, and got some aluminum flat bar from Home Depot, cut a couple of short pieces (bout 4-6 in) drilled a hole in it, and bolted it to the holes on the upper support, then bent it just enough to firmly hold the fans in.
Old Apr 7, 2006 | 01:48 PM
  #22
jm's customs's Avatar
this is it installed, see how the shroud sticks out 2 inches.
here you can see the gap that was filled between the two shrouds.
here you can see how it fits, i also drilled a small hole in the top to attach the radiator hose to keep it from hangind down.
Old Apr 7, 2006 | 02:27 PM
  #23
Revelation222's Avatar
Got it! Makes more sense now, hehe. You went a little above what was required. Very nice. I hope you cleaned up the fans a little more before the final install. It would be tragic if you did all of that custom work and left it unfinished. j/k
Thanks for the help guys!
Old Apr 7, 2006 | 03:49 PM
  #24
yeah i hear ya, im not done yet i still need to fiberglass some more, and then paint. itll be clean lookin' when im done.
Old Apr 7, 2006 | 04:54 PM
  #25
I didnt figure you would Post some pics when you get it done. It will probably look like a factory install when you are done. Kudos!
Again, thanks for the help.
Old Apr 8, 2006 | 02:13 PM
  #26
FastCrewCab4x4's Avatar
Are those pic's of the mock up? if not why's the original fan still there?
Old Apr 8, 2006 | 04:10 PM
  #27
I believe that it would be safe to say that he was just test fitting his work.
Either that, or he did just as many drugs as I did when I was younger. That short term memory loss is a b_tch
Old Apr 8, 2006 | 07:06 PM
  #28
agreif's Avatar
Here, try this. Should clear up any questions.
http://bertok.us/agreif/fans/fanstech.htm
Andrew
Old Apr 8, 2006 | 11:33 PM
  #29
just a test fit, and i havent got my wire harness from whit1 yet, and im not done making the should, and.... i am just kidding
SS94S10
Jan 3, 2019 01:57 PM
CD82
Oct 23, 2015 07:32 AM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
