EFan problem....not a tuning issue
Old Mar 14, 2011 | 05:06 PM
  #41
01Blackerado's Avatar
Ok, Ill try that... I'll see if I can do it tonight and give you the results. I need to get some 18-22 gauage wire and crimp the pin and insert to the red slot. I haven't done that part yet. Whats the overall verdict though? If I get nothing on 33 does that mean my problem just got worse than we originally thought?
Old Mar 14, 2011 | 05:09 PM
  #42
bullygoat's Avatar
Honestly I'm not sure. I'm just trying to eliminate things at this point.
Old Mar 14, 2011 | 05:16 PM
  #43
Ok cool.. I just found some good 18g wire so Im starting this crimp now. Ill pin it and let you know. Thanks for all your help thus far... been a hell of a run at this lol
Old Mar 14, 2011 | 05:39 PM
  #44
LMAO, ok WTF do i have here...I get outside and get ready to pin 33 red... well guess what, theres already a green wire in 33 red!?!?!?! W T F
Old Mar 14, 2011 | 05:40 PM
  #45
Should I try cutting that wire and see if it stops all this nonsense?
Old Mar 14, 2011 | 06:20 PM
  #46
bullygoat's Avatar
That's right, Pin 33 goes to the HVAC recirculation door in hte non e-fan trucks. We just need to see if ground is being applied. If you have a pin made up, I'd use that to keep from cutting wires unnecessarily. Just pull the current one out and put yours in.
Old Mar 14, 2011 | 06:22 PM
  #47
Ok small issue, I cant get the original out... am i missing something with this? Im afraid to pull on the wire too much cause i I dont want to pull it out of the pin itself
Old Mar 14, 2011 | 06:27 PM
  #48
bullygoat's Avatar
You have to pull the colored cover off and then carefully pry the white tab away from the pin just enough to release it. Then put the new pin in and put the cover back on making sure all of the tabs are inside the cover.
Old Mar 14, 2011 | 06:30 PM
  #49
shittastic, yeah I tried that too and those colored covers are on there pretty tight, I hate plastic cause I always break something... Ok is there an easy way to get that colored cover off? my fingers are two sizes too large to crimp the white plastic tabs in as im pulling the cover off.
Old Mar 14, 2011 | 06:36 PM
  #50
bullygoat's Avatar
There should be a little tab on the side of the pin protector where the white plastic shows through. Push on that with a flat head screw driver and pull the cover up. It should then just come off and hinge off the other side.
