eaton magnacharger bower question
Old Nov 28, 2004 | 11:32 PM
  #41
Originally Posted by moregrip
Hey X, are you stock now? or do you have any mods?
Are you planning on doing before and after dynos runs?
My pig turned 240 rwhp 320rwq bone stock. I'll have some supporting #'s later this week.
Right noe basically stock cept 2 two chamber flows dumped-those r coming off and bullets going in place of em.hehe Those r good #'s-And yes before and after will be done.
Old Nov 28, 2004 | 11:41 PM
  #42
moregrip's Avatar
what a rush!
Originally Posted by gametech
Am I missing something? Other than looking cool I can't figure any possible reason for twin S/C's. If you want more flow capacity, get a 3.3L whipple.
M90 (90 cubic inches per revolution) The smallish blower needs to spin fast to make boost, This higher speed combined with a smaller sealing length means leakage at low engine speeds is reduced and low RPM boost increased = full boost by 2000 RPM. So off idle boost, a modified roots strong point, is insane and the increased CFM keeps er breathing up top.
You won't get both from a 3.3L. Off idle is a twin screws weakest point(any off boost condition).
Now that M90 x 2 =
Old Nov 28, 2004 | 11:44 PM
  #43
M90x2=insane power and neck snapping ability!!!!!!
Old Nov 29, 2004 | 12:53 AM
  #44
gametech's Avatar
Moregrip, thanks for the more detailed explanation. However, since our factory torque converters on these trucks flash to near 2000 rpm anyway, I guess the low rpm advantage would mainly apply to the stickshift trucks? Also, does anyone know what the difference would be on the topend having to overcome the extra power needed to spin 2 blowers? BTW, how much would 2 m90's and associated bracketry weigh?
Old Nov 29, 2004 | 01:09 AM
  #45
moregrip's Avatar
what a rush!
sounds like a perfect match, flash stall @ 2000, full boost @ 2000.
Any way you slice it, the 3.3 will not be as responsive.
The weight of the brackets would depend on the setup. That's pretty much an unknown as I don't believe any LS motors have gone there.
The M90 is very easy on power consumption though, a little too late for me to chase down specs but I can tomorrow.
Old Nov 29, 2004 | 01:10 AM
  #46
moregrip's Avatar
what a rush!
the advantage is twofold, one; off idle, two; any off boost condition.
Go5.3tt06
25
Sep 4, 2016 10:25 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
