eaton magnacharger bower question
Old Nov 28, 2004 | 04:11 PM
TwoFast's Avatar
Default eaton magnacharger bower question
just thinking. Doesn't the old sidemount magnacharger use the eaton M90 blower? Isn't that the same blower that the GTP uses. Couldn't you get a rebuilt Eaton M90 off ebay (there are thousands of them on ebay) and then buy all of the mounting and other accessories from Magnacharger and make your own old school magnacharger for less than half the price. Would it work. Just wondering.
Old Nov 28, 2004 | 04:17 PM
Well with all the work you would have to do IMO it would be easier to just order the Radix rather than creating your own. But your right there is a ton of em on ebay so you could get a good deal on one and rebuild it if you wanted too.
Old Nov 28, 2004 | 04:19 PM
moregrip's Avatar
what a rush!
Yes it was/is the M90.
Old Nov 28, 2004 | 04:20 PM
moregrip's Avatar
what a rush!
er'go
http://www.superchargersonline.com/p.../53/60-001/002
Old Nov 28, 2004 | 04:21 PM
BlownChevy's Avatar
blownerator
25 Year Member
The M90 off of the GTP and the M90 that was used on the sidemount magnacharger are two different housings. You would be better off getting the newer RADIX system for your truck.
Old Nov 28, 2004 | 04:23 PM
MacADaYear's Avatar
I think hes refering to price being a factor also. If he is talking about half price on a older system, thats is nowhere near the range of a RADIX.
Old Nov 28, 2004 | 04:25 PM
Very true,but it seems as if the RADIX would be more effective than the old side mount M90.
BlownChevy's Avatar
blownerator
25 Year Member
Understood, but if you get down to it the savings would not be worth it. If you are looking for a side mount set up, check ebay they come up all the time for around 2gs.
Old Nov 28, 2004 | 04:27 PM
MacADaYear's Avatar
How bout a homebuilt twin turbo setup Wasnt someone working on one?
Hey guys, if you all donate 50 bucks to me ill make a homemade turbo and post the plans how to make it
Old Nov 28, 2004 | 04:29 PM
moregrip's Avatar
what a rush!
somebody once recommended twins! (M90's)
