E.T. GAINS AFTER BOLT ONS
Old Sep 18, 2002 | 02:10 PM
BUSA13R's Avatar
Default E.T. GAINS AFTER BOLT ONS
I HAVE A '02 GMC REG CAB SPORTSIDE W/ 5.3 AND 3.73 GEARS.STOCK RAN 10.12 @70.2MPH IN THE 1/8MI. AFTER AIRMAX,TB SPACER,GIBSON SUPERTRUCK,AND HPP3 THE TRUCK RAN A BEST OF 9.80 @ 72.6MPH.I STILL BELIEVE THE TRUCK IS LEAN AND TQ MANAGEMENT IS NO HELP,IS THIS THE NORM FOR THESE BASIC BOLT-ONS? AND WHAT KINDA GAINS HAVE OTHERS BEEN GETTIN.
Old Sep 19, 2002 | 01:04 AM
graygmc's Avatar
Default Re: E.T. GAINS AFTER BOLT ONS
what are your 60 ft times before and after?
Old Sep 21, 2002 | 09:24 AM
BUSA13R's Avatar
mid 2.30's before and pretty consistant 2.25's after.i'm sure what i might of gained down low ,tq management killed it!
Old Sep 21, 2002 | 10:16 PM
I doubt you even felt TQM with those mods. once you put a shift kit in and a power adder Ie S/C or N2o (for ricers its NOZZ YO), then youll feel it. Itll feel like your truck just got punched in the chest and it got the wind knocked out of it.Itll be noticable during your shifts, and in my case 2nd-3rdshift, and rightafter the truck hits about 80, it kicks in, and then it picks up and goes agian. I must say you made a good choice on the Gibson Super truck, i have it and it sounds sweet..IMO the next mod should be a shift kit and a vette servo(i dont have a servo yet, but thats coming too) then a TQ converter. Try makeing a ramair setup out of either dryer duct or pvc pipe from the Hole in the lower valance to the bottom of the plate beneath your air filter(youll have to cut a hole in the plat, or make one. I did this on the old mans yukon, and you feel the difference. Look into the free mods such as porting you throttle body to 75mm, and Grinding the tb to 4.7 volts.
good luck, and welcome to the club
John
Old Sep 22, 2002 | 12:41 AM
red53gmc's Avatar
I don't think you're lean with those mods. The trucks are actually rich from the factory so leaning them out a little is good.
Also, torque management has nothing to do with power down low. TQ MGMT pulls timing during the shifts if it sees too much torque at the shift point.
Old Sep 23, 2002 | 03:38 PM
BUSA13R's Avatar
I HAVE A AIRMAX INTAKE SYSTEM,NO PLATE NO MORE AND GRIND WHAT OFF THE TB?
Old Sep 23, 2002 | 03:42 PM
BUSA13R's Avatar
TM IS THEIR WHEN THE TRUCK WON'T TURN THE TIRES OVER ON THE STREET.IT'S DEAD OUT OF THE HOLE,3.73 GEAR AND 1ST GEAR RATIO OF 3.06:1 SHOULD BLAZE THE TIRES STOMPING ON IT!FROM DEAD STOP OF COURSE.
<small>[ September 23, 2002, 03:43 PM: Message edited by: BUSA13R ]</small>
Old Sep 23, 2002 | 05:24 PM
Nick99Chevy's Avatar
TQM pulls back power to soften shifts, It's not a factor from a stop.
shawn96gmc
May 17, 2016 04:15 PM
ClintBeastwood
Aug 31, 2015 05:30 PM
fastjweb
Aug 31, 2015 09:57 AM
4B11T
Jul 13, 2015 03:48 PM
mrgrim
Jul 8, 2015 08:12 AM
