E-Fans SUCK!
Old Aug 3, 2010 | 09:26 PM
brent5631's Avatar
No problems here. running a nelson harness that I converted to the two pin style.
Old Aug 3, 2010 | 09:37 PM
slamdlsx's Avatar
best wiring diagram to follow? i have ls1 fans here but havent installed them. Not paying 100 bucks for a harness to burn up on me.
Old Aug 3, 2010 | 09:50 PM
charcold-bowtie's Avatar
i did that as well. Havent had trouble till about 2 weeks ago, heated the truck up twice. Replaced all the relays, but the truck isnt running right now.
Old Aug 4, 2010 | 07:04 AM
double047's Avatar
14 Second Truck Club
Subscribing.
Old Aug 4, 2010 | 11:44 AM
budhayes3's Avatar
PT's Slowest Truck
Aside from a few relays burning out recently, my 05 efans and Nelson harness have been performing flawlessly (knock on wood). If done properly, efans are a nice mod...seems the biggest problems guys have are related to harness issues. Seems like the quality of the Nelson harness has gone downhill unfortunately, glad that I got mine before they started getting semi-mass produced, I suppose.
Old Aug 4, 2010 | 11:47 AM
Holty's Avatar
Notorious BIG
My 05 efans and Nelson harness also work perfectly other than replacing relays once in the past 3 years.
Old Aug 4, 2010 | 12:16 PM
93Polo's Avatar
Has anyone had problems with the Blackbear Harness?
Old Aug 4, 2010 | 12:22 PM
PathfinderJr's Avatar
Not that I've heard. A Blackbear harness is the one I'll be going with unless I just make my own.
Old Aug 4, 2010 | 01:03 PM
nonnieselman's Avatar
Ive never burnt a relay or had a single problem with my LS1 efans or 05 fans.
I built a harness off that diagram using 10ga Hi-temp wire for the main wires and 14ga wire for the signal wires.
I also didnt use the AC Clutch as a "switch" it cycling off and on will do a number to a relay. Let your PCM control the fans, and put 2 override switchs in the cab.
Old Aug 4, 2010 | 06:37 PM
brent5631's Avatar
This schematic that Atomic has posted a number of times is the traditional two pin harness. Its what I run.
