E-fan PCM tuning ?
Old Mar 24, 2005 | 02:09 PM
tdrumm's Avatar
Default E-fan PCM tuning ?
I want to do 05 e-fans when I swap in my cam, but with the cost of the radiator too, I don't know if I'll be able to swing it.
Do you think that I would be okay if I had my PCM programmed to turn on the fans without them being there? That way when I get them I could just plug them in and be ready to go without needing a re-tune.
Old Mar 24, 2005 | 02:12 PM
BlownChevy's Avatar
blownerator
25 Year Member
you will be fine. Tune away.
Old Mar 24, 2005 | 02:57 PM
Eye-P's Avatar
Brian- what ever happened with your fan install. Were you able to find the 2nd pin-out?
Old Mar 25, 2005 | 06:20 AM
tdrumm's Avatar
Cool, thanks
Old Mar 25, 2005 | 10:36 AM
budhayes3's Avatar
PT's Slowest Truck
I just purchased e-fans from G&R Auto Parts in Oklahoma City...same company that I got the 145amp alternator from ($100 shipped ebay). $224 shipped to my door. I just purchased them yesterday, so they'll probably be here next week. Here's the website: http://www.gandrautoparts.com/ Go to the parts locator link at the upper left...I typed in for an 05 2500, and the fans are supposed to fit a truck or Avalanche. For some reason, the Tahoe fans are a different part number, but I don't see what the difference could be.
I'm probably gonna get a radiator from the Radiator Barn...it's less than $240 shipped. Then it's just a matter of gettin in touch with Bryan to get the PCM tuned and get a harness
Old Mar 25, 2005 | 09:46 PM
ok i got a question i put elefans on the truck and set all the settings with ls1 edit i used pin 42 on the pcm and i dont know what the deal is every time the engine is running the fans are on but if you kill the engine leaving the key on the fans turn off like every time it sees a rpm signal it turns the fans on i dont know what the deal is
btw its a 2000 gmc
thanks
Old Mar 26, 2005 | 12:18 AM
SnakeOiler's Avatar
Hard to understand without the punctuation, but I think you are saying the fans run all the time when the engine is running and when the engine is not running, neither are the fans. Is this correct? If so, then your problem is: Why are the fans running continuously when the engine is running?
This could be a number of things. Did you make the correct changes with Edit? What were the temps set at? Have you verified your wiring? The fans could be seeing constant power when the engine is running.
Old Mar 26, 2005 | 02:57 PM
70LS_Nova's Avatar
thats exactly the prob and i dont know why
mr03silverado
Jun 26, 2016 06:05 AM
thunder550
Oct 8, 2015 04:53 PM
Suburbazine
Aug 9, 2015 01:17 AM
bjamick
Aug 5, 2015 10:51 PM
chvy=power
Jul 27, 2015 10:06 AM
