dyno runs
Old Jul 30, 2002 | 10:41 PM
  #21
CashDudeHomie's Avatar
Default Re: dyno runs
If the G80 is the factory locker, then what is the factory posi, and is it any good? Or is the G80 the only one available?
Old Jul 31, 2002 | 12:00 AM
  #22
364LS1truck's Avatar
so, the g80 comes in out trucks stock. but it's a locker. but you guys are saying that the g80 is a posi also
Old Jul 31, 2002 | 12:13 AM
  #23
oxidizr's Avatar
Moderator / Sponsor
It, the G80, is a clutch based "locker." It by definition should be called a posi as it works like a eaton posi but can be engaged or disengaged. Unlike a true locker which has no friction material, the G80 can quickly wear its clutch material out with high torque applications and loose functionality (Upon disassembly of mine the cluches were burnt and worn heavly for the 15K they had on them...which can be attributed to my nitrous use). Mine worked out OK but as I climbed in power the G80 could not match pace.
Richard
Old Aug 1, 2002 | 12:32 AM
  #24
so what rearend are you using now ox?
Rafe19
Oct 18, 2016 12:27 AM
stealthperf
34
Feb 14, 2016 11:35 AM
rednekferlife101
32
Jan 8, 2016 10:42 PM
thunder550
Oct 8, 2015 04:53 PM
03regcab sierra
20
Aug 3, 2015 12:11 AM
