Driving habits with a cam?
Old Mar 11, 2008 | 10:53 AM
03GMC's Avatar
Default Driving habits with a cam?
Just got 215/220 cam install with dual springs. Someone said something about letting the truck warmup before getting on it because the springs need to be warm or they will break.
So do I need to let it sit there for 5 minutes every morning or can I just go easy on it?
Old Mar 11, 2008 | 11:00 AM
Zick's Avatar
Just go easy on it. Seeing that you are in TX, I doubt you guys get very cold mornings.
I always just kept it under 2K rpms till it warmed up.
Old Mar 11, 2008 | 11:04 AM
03GMC's Avatar
Well its been in the 30s the last few mornings. Thats cold to me. Lol.
Think I need to invest in a remote start.
Old Mar 11, 2008 | 11:16 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Just let the oil get a chance to warm up before you romp on it, I keep it under 3000rpms until the water temp is up to operating temps and oil pressure is normal.
Old Mar 11, 2008 | 11:39 AM
budhayes3's Avatar
PT's Slowest Truck
That's one thing I really like about the LS6 springs, they're not brittle so I can just crank it up and go...even though I usually let it warm up a bit on really cold mornings since my bones are brittle lol. When I had the Comp 915's I was concerned about cold operation.
Old Mar 11, 2008 | 11:58 AM
03GMC's Avatar
Yeah these are good to .650 lift. Just in case I want a bigger cam down the road. Just extra insurance I guess.
Old Mar 11, 2008 | 01:51 PM
black4.8's Avatar
high performance springs are prone to breaking when cold. let some heat build up in them before high rpm. i usually let my truck get up to temp. before driving. should let the oil warm up before romping on it anyways.
Old Mar 11, 2008 | 03:26 PM
brodystruck's Avatar
IMHO, by the time water temperature hits 130+ you're good to go.
It's just common sense, drive the truck around a little bit before you go romping on it. You don't need to let it get all the way up to 170+ before you put it in gear just a slight warm up is all you'll need. And during the summer it will be even less of an issue.
ARC
57
Feb 21, 2022 10:54 AM
LARRY01Z28
Aug 1, 2015 10:15 PM
elpyro89
Jul 28, 2015 05:51 PM
ssierra08
Jul 15, 2015 06:40 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
