dot-to-dot, cam/crank relationship
Old Mar 8, 2017 | 01:06 PM
TXsilverado's Avatar
I agree, although if it was that close it was a big cam. A degree wheel is the way to go although with a non adjustable timing set you aren't accomplishing much other then finding out it's not right.
yep. big cam on 106icl in a flat top LS2 with larger than stock valves in milled heads. I had to cut the pistons .090 to clear the exhaust valve. luckily I didn't start cutting pistons before verifying the cam specs.
Old Mar 8, 2017 | 01:28 PM
Vortec350ss's Avatar
Anyone else want to comment on how nasty that cam gear looks? Good lord that engine is dirty...
How many miles on this pig? What kind of cam are you putting in?
Old Mar 8, 2017 | 01:39 PM
03sierraslt's Avatar
Originally Posted by wretched73
Not to hijack, but what timing set would you recommend? Would probably help OP and myself
Cloyes Timing set with a Z chain. Basically the tightest, strongest single chain you can get.
Old Mar 8, 2017 | 02:34 PM
wretched73's Avatar
Is that the Hex adjust?
Edit- Is this the same one?
Amazon Amazon
Old Mar 8, 2017 | 06:50 PM
Yes it is. That looks like it.
