dot-to-dot, cam/crank relationship
I'm about ready to pull the cam but can't determine the dot-to-dot relationship of the cam and crank. If the picture shows up, you can see the dimple in the cam gear (don't know if that's the one I'm looking for) and there's a dot on the end of the crank, but they don't line up.
What gives? https://cimg7.ibsrv.net/gimg/www.per...49b14b7f7d.jpg |
Line up the dot on the cam gear with the dot on the crank gear behind the oil pump.
Take the pump off. Dot is on the crank gear
OK, thanks guys. I'm in the process of getting the pump off (you can see I've taken it apart) but am having a heckuva time getting the oil pan dropped. Thanks for the answers!
The pump does not need to be pulled tilo see the dot.
Run a degree wheel too. I had a cam ground incorrectly that would have cost an engine if i didnt take 30 min to check.
The stock timing sets on these motors are so loose it's pitiful. I will never swap a cam and put a stock timing set back on. A lot of people do though. To each their own.
(Post 5401475)
Dont pull the pump off, not worth fighting with that oring on the tube. You can see the crank dot behind it. If its way off you can move it a whole chain link but obviously a adjustable timing set gives you finer adjustments.
(Post 5401480)
