dot-to-dot, cam/crank relationship
Old Mar 7, 2017 | 08:56 PM
SunBUm's Avatar
Default dot-to-dot, cam/crank relationship
I'm about ready to pull the cam but can't determine the dot-to-dot relationship of the cam and crank. If the picture shows up, you can see the dimple in the cam gear (don't know if that's the one I'm looking for) and there's a dot on the end of the crank, but they don't line up.
What gives?
Old Mar 7, 2017 | 09:04 PM
03sierraslt's Avatar
Line up the dot on the cam gear with the dot on the crank gear behind the oil pump.
Old Mar 7, 2017 | 09:05 PM
BigBamaBoy65's Avatar
Take the pump off. Dot is on the crank gear
Old Mar 7, 2017 | 09:19 PM
SunBUm's Avatar
OK, thanks guys. I'm in the process of getting the pump off (you can see I've taken it apart) but am having a heckuva time getting the oil pan dropped. Thanks for the answers!
Old Mar 7, 2017 | 11:35 PM
TXsilverado's Avatar
The pump does not need to be pulled tilo see the dot.
Old Mar 7, 2017 | 11:36 PM
Run a degree wheel too. I had a cam ground incorrectly that would have cost an engine if i didnt take 30 min to check.
Old Mar 8, 2017 | 05:46 AM
The stock timing sets on these motors are so loose it's pitiful. I will never swap a cam and put a stock timing set back on. A lot of people do though. To each their own.
Old Mar 8, 2017 | 05:47 AM
I agree, although if it was that close it was a big cam. A degree wheel is the way to go although with a non adjustable timing set you aren't accomplishing much other then finding out it's not right.
Old Mar 8, 2017 | 07:07 AM
Atomic's Avatar
I have a gauge for that
Dont pull the pump off, not worth fighting with that oring on the tube. You can see the crank dot behind it. If its way off you can move it a whole chain link but obviously a adjustable timing set gives you finer adjustments.
Old Mar 8, 2017 | 07:28 AM
wretched73's Avatar
Not to hijack, but what timing set would you recommend? Would probably help OP and myself
