dc sport long tube headers?
Old Nov 18, 2007 | 08:13 PM
  #211
RedHot04's Avatar
Originally Posted by BlewSilverado
Whats the best way to use my stock cats with the DC headers? Should I get a ory and hack it up to use with my stock cats? Any other suggestions for a 2wd 5.3 with a single 3 inch exhaust?
yep...don' use the stock cats do it like this:
https://www.performancetrucks.net/fo...&postcount=169
Old Nov 18, 2007 | 11:22 PM
  #212
Nasty73z's Avatar
Those cats with the O2 bungs are ceramic element though, not metallic. They do sell metallic cats for a lot cheaper than the Magnaflow's they're knocking off...
http://cgi.ebay.com/ebaymotors/2-5-M...spagenameZWDVW
Old Nov 19, 2007 | 12:25 AM
  #213
RedHot04's Avatar
?? Yes, I got the high flow ceramic ones. But you're info about the price is incorrect. Mine cost much less than the metallic ones, by about $20 some dollars each.
Old Nov 19, 2007 | 11:11 AM
  #214
Nasty73z's Avatar
I know that they're cheaper. But the metallic cats have a higher flow rate and will last longer than the ceramic element cats.
Old Nov 19, 2007 | 06:51 PM
  #215
BlewSilverado's Avatar
I like the Idea of the cats you guys are talking about. I think I will check and see if they make the metalics with the o2 bung. What about the rest of the y pipe? Do you think there is enough room to weld these cats in a ory y pipe? Or from the cats back will a custom pipe need to be made. I dont like the fact that a exhaust shop will have to make something from scratch ( you never know what you will get) and it wont be mandrel bent.
Old Nov 19, 2007 | 08:56 PM
  #216
20002wdchevy's Avatar
14 Second Truck Club
Hey guys i dont have AIR or EGR on my 00 pickup but the AEM headers i ordered have the fittings and instead of using block off plates i'm going to use freeze plugs. just a tip for anyone who cant find plates.
Old Nov 19, 2007 | 09:00 PM
  #217
fastrt's Avatar
11 Second Truck Club
have you guys thought of puting a 3" high flow cat AFTER the y and extend the one o2 for the left pipe? I think I will just put in a pipe to interchange for inspection time. Anyone know if getting the rear o2's tuned out will effect the inspection machines in texas?
Old Nov 19, 2007 | 09:11 PM
  #218
BlackGMC's Avatar
Resident Retard
I believe that in texas you can 2 "not readies" and still pass when they check the codes and system checks. I am not sure how many "Not Readies" deleting the cats makes.
Old Nov 19, 2007 | 10:05 PM
  #219
southern_chevy's Avatar
would it throw one for each heater and sensor or just the sensor or just the heater?
Old Nov 19, 2007 | 10:11 PM
  #220
fastrt's Avatar
did you tune yours out with efi live? did you get your y fabbed up?
