Crossed Drilled Rotors.....Vol II
#101
I think all in all we can say this....
Ok.. maybe cd-ed dosent help much. BUT, for 180bucks for 2 front rotors that are thicker than stock and seem to be performing well ... who is really losing here...
Sure id love to drop 3 grand on a NICE braking system... but for a couple hundered bucks im happy.
#102
Originally Posted by -= MacADaYear =-
You worked at a brake company you tell me.
If you answered your questions at work the way you do here, no wonder you got fired.. all talk
God, who uses facts, logic and science to answer questions pretaining to engineering these days.
Maybe from now on, instead of doing wind tunnel testing; I'll just stick my hand in front of the radiator.
#103
Next issue; Girls are hotter than guys..
#104
Originally Posted by treyZ28
ever heard ofconfidentiality? A nice thick book you sign when you join a company? Says you cant tell anyone about this stuff durring and after your employment? You how fired his *** would be for releasing data that his company spend tens, if not hundreds of thousands of dollars testing? Are you that dumb?
As far as your credibility... you told me how all the real rally racers dont use cd-ed rotors but for some reason 75% of the webpages I looked at rally cars had them... thus its becoming more and more obvious how full of **** you really are
#105
Originally Posted by Chingon
You really think the Big 3 cares about anything other than the bottom line? You are the real tool.
Those Firestone tires that came with the Explorers awhile back must've met their standards too. Now more than, what was is, 200 people are dead?
In case you didn't know, it's all about money. Think whatever you want though.
#106
Then dont come to me with rediculious requests for numbers I cant get when you ran the friggn tests and you still cant post em
PS: what are you qualifications to be arguing right now without data?
#107
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Uhhh.... do you know anything about the standards set forth by the big three. I am spending months doing durability testing and performance for GM's new vehicles. I guess Nueremburg just isn't good enough for you
Bottom line man, that's what it's all about. Sorry to burst your bubble.
#108
ohh good, I'm glad you took the hint. Took you long enough
And girls are hotter than guys yes... but is that with ventilation? what kinda clothing material we talkn about here. And those clothes better be name brand or FORGET IT! I WANNA SEE NUMBERS!
#109
POST SOME NUMBERS then if you guys are so good with this. Tell us the tests you did and the numbers that came back
Chingon, the advantages of braided brake lines are that they do not wear out like rubber lines will, when your truck ages and your rubber lines start to fade, they will bulge when braking is applied, not allowing for as much pressure in the line itself. because your vehicles are new or at most 4 years old to most of the people i am speaking with, you will not experience this because your lines are pretty much new. I will be doing the braided brake line swap when i lift my truck. i'll inform you if there is any difference. steel brake lines will not decrease stopping distance only pressure in the lines, so it will decrease brake fade. This other guy told you pedal feel would be different, yet its not. So you have just told me he is wrong and you still believe him?? Keep in mind the tests that were run we run under ABS activation, so if you lived in snowy and icy regions where your vehicle would have many more abs activation than someone in cali. Therefore you will not see the pad life cut inhlaf unless you stop hard enough to have abs activation. Hope this helps.
#110
No, it's because I'm not a naif like you who believes everything they hear or see
