Crankshaft sensor???
Old Jan 17, 2008 | 11:17 PM
terravast4's Avatar
Default Crankshaft sensor???
Can anyone out there help me. For the past few days the truck has been idling really rough but not all the time. I can sit at a light and it will idle fine. drive to the next light , stop, and then it bucks like hell rpm's dipping below 500. once I get off idle it rins fine. I have also experinced stalling about three or four times in the past week but always start's right back up. now when i slow down to a stop quickly the rpm's are all over the place 800, 300, 500 feeling like it is about to die. Has anyone experienced this? I think it is the crank sensor but not 100%. If anyone has experienced this let me know.
Old Jan 17, 2008 | 11:55 PM
thunder550's Avatar
High on diesel fumes
Sounds like an idle airflow problem to me. What tune are you running?
Old Jan 18, 2008 | 07:46 AM
terravast4's Avatar
I had a custom tune done here at a local shop. The thing is it does not akways idle bad. I can drive some short trips and it will idle fine. It seems if it was an air/idle issue it would be all the time. It tripped a code last night so I am gonna have that code pulled today. as soon as the check engine light came on it really idled bad I had to brake and rev the engine over 500 rpm's just to keep from stalling at every light.
Old Jan 18, 2008 | 08:58 AM
thunder550's Avatar
Hmmm...well let us know what the code is, maybe that will shed some light on it.
Old Jan 18, 2008 | 09:04 AM
BLACKND's Avatar
I know when I had my 04 cammed crew cab, that it pulled a move like this on me twice. When I would sit idle or just off idle it would run rough as hell, sound like ****, and buck RPM's like crazy until I got it moving good. Seemed like it did it mostly in first gear at low rpm's. Run almost like it was reduced power mode.
I checked everything, never thru any codes, but turned out to be a bad plug wire. A header burned it up. Put the stock plug wires back on and it ran fine. I know it sounds like a simple solution and it might not help one bit, but it would be the easiest to check.
Old Jan 18, 2008 | 09:42 AM
terravast4's Avatar
I am getting ready to pull the code here soon. It is only bad at idle. over 500 rpm's no issues at all. runs great, pulls hard. once I slow down to a stop rpm's drop below 500 then jump up. then may idle just fine. Oh well, the code will tell all.
Old Jan 18, 2008 | 11:47 AM
terravast4's Avatar
Pulled a code p101-maf or vaf in ckt. anyone?
Old Jan 18, 2008 | 12:19 PM
thunder550's Avatar
Might try cleaning the MAF sensor...there's some kind of electrical connector/sensor cleaner that you can use that's a no-residue cleaner. That would be the place to start, other than checking to make sure everything is plugged in correctly.
Old Jan 18, 2008 | 01:31 PM
Bish's Avatar
Contact Cleaner for electronics works well or you can use a MAF specific cleaner. Not sure if you have one but when my Idle air Control (on TB) would get dirty it would act in a similar manner.
Old Jan 18, 2008 | 04:27 PM
terravast4's Avatar
Already cleaned the throttle body and maf. Same ****.
