converter questions
Old Nov 30, 2003 | 03:20 PM
Banned
Default converter questions
ok, i'm tired of this burned out stocker and i'm looking to go with something like a PY3600, but every so often i have quite a bit of weight in the bed of the truck...i don't tow much so i wasn't sure if there was any difference in towing or having it in the bed when you're thinking about the converter and how it affects towing weight or capability. and also, WHY does the converter stall speed being higher, say 3600-4k affect towing ability?
Old Nov 30, 2003 | 10:46 PM
Banned
to the top
Old Nov 30, 2003 | 10:57 PM
Flyer's Avatar
Not sure on exactly why it affects towing ability, but I would guess that it is something with the amount of heat it will produce. 3000 more pounds would make a 3800 stall more like around 4400 probably and be hard on eerything including the already proven weak spot tranny and converter.
Old Nov 30, 2003 | 11:04 PM
Texas Terminator's Avatar
11 Second Club
damn matt! how long have you been in here? the difference is slippage. slippage equals heat. that is why you don't use a high stall converter if you are going to haul anything. so how often is "every so often" and how much weight are you talking and how far? a 3600 is pretty steep anyway.
Old Dec 1, 2003 | 10:13 AM
BigKID's Avatar
Also usually the the case size has to be reduced to achieve the higher stall which means a smaller lockup clutch. The smaller clutches cannot hold the extra weight.
Old Dec 1, 2003 | 03:56 PM
Banned
every so often is like, once a month if that...and definatly under 1000#, probably more like 400-700 if that even.
GXPJAY
Feb 13, 2022 08:15 AM
Jblake
Aug 17, 2015 12:59 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
grantpo
Jul 15, 2015 12:21 PM
