Cam choice fort the Wife's 'Hoe
Old Nov 30, 2003 | 11:06 PM
Question Cam choice fort the Wife's 'Hoe
2002 Z71 Tahoe
I almost have the wife convinced that she needs a cam upgrade in her '02 'Hoe. We are not looking for a high horsepower screamer here, just some more low end grunt. I have my old cam from my Z28 laying around and was wondering if it is a wise choice? It is a Comp Cams 216/220 .525/.532 114LSA. Would this cam work well in here 5.3L? Absolutely cannot sacrifice drivability but would like a little more low end power.
Thanks
Josh
Old Nov 30, 2003 | 11:23 PM
Flyer's Avatar
That seems like a little mild. I think it should work OK. Have you thought about a new converter too?
Old Nov 30, 2003 | 11:29 PM
FILE's Avatar
That would be an awesome choice. I whished I would have gotten that one.
Old Nov 30, 2003 | 11:30 PM
FILE's Avatar
If you don't put it on, will you consider selling it?
Old Dec 1, 2003 | 08:37 AM
marc_w's Avatar
I actually think that cam is a little big in the 5.3 - if you don't want to loose low-end power.
I read about people on here loosing low-end with the next one down - the 212/218 .522/.529 114.
I personally think the 206/212 .515/.522 112 would be best...
If you add about 600rpm to the lower rpm range listed here..., I think that'll give a good idea to where the cam actually makes the same power as stock... From there, it builds.
IE: the cam you first mentioned was good from 1300-6300. I'd guess it'll start making at least the same power as stock, by 1900rpm... which would probably feel like a huge flat spot when the TC locks up at cruise...
Old Dec 1, 2003 | 09:15 AM
1BADHD's Avatar
Your in the same boat as me. This is the cam I have come up with after MANY, MANY dicussions with memebers, Crane Cams and Comp cams. Its a custom grind. 212/212, .528"/.528", 112 LSA with +4 degrees of advance. It will net great gain and loose very littel if any low end.
Old Dec 1, 2003 | 01:18 PM
2001si3rr@'s Avatar
Thumbs up
Originally Posted by NO CATZZ
2002 Z71 Tahoe
Thanks
Josh
I really think it's a great cam not only because that is the same exact cam I will be installing in my truck after the new year but with the right converter, bolt on's, and edit tune could make a nice performer. If you install it before the new year let me know the out come?
Old Dec 1, 2003 | 04:39 PM
sambandit's Avatar
Good question. My wife has the exact same vehicle. I'd like some input here as well!
OHsixLS3
Dec 27, 2016 09:30 AM
gmc6.0
Oct 31, 2015 12:34 PM
JordanH
Aug 8, 2015 07:59 PM
LARRY01Z28
Aug 1, 2015 10:15 PM
steves86ta
Jul 28, 2015 10:21 AM
