computer
Old Sep 9, 2009 | 07:07 PM
318BANDIT's Avatar
Default computer
could someone post up a link on how to change out computer. because i got a new nelson tune and wanna put it n myself. also i need the crank relearn procedure
Old Sep 9, 2009 | 07:32 PM
03 BLACKOUTSSS's Avatar
Find computer, loosen the two 7mm bolts in the harness (one per side) remove harness, remove PCM, install is the reverse of removal. Might not need the crank relearn, I didn't in my 02 (not sure if anything has changed).
Old Sep 9, 2009 | 07:45 PM
318BANDIT's Avatar
ok appreciate man hate to sound dumb but exactly where is it located
Old Sep 9, 2009 | 08:03 PM
MikeGyver's Avatar
You probably think that guys that put their vehicle specs in their signature are braggarts.
Old Sep 9, 2009 | 08:15 PM
viciousknid's Avatar
Where's the Beef?
PCM is probably what you wanted to search for to find the other threads like this one.
The PCM is located next to the battery and down a bit. You'll see it. However, Knowing what year your truck is would help as i think the 08+ models are in a different place.
Old Sep 9, 2009 | 08:36 PM
318BANDIT's Avatar
its a 2005 ccsb gmc sierra wit a 5.3 vortec
Old Sep 10, 2009 | 05:48 PM
budhayes3's Avatar
PT's Slowest Truck
Then it's right next to/beneath the battery...you may need a screwdriver to pop the clips that hold it in if you don't have strong fingers...and a 7mm socket as mentioned above.
Old Sep 10, 2009 | 08:36 PM
ScreaminChevy's Avatar
Make sure to disconnect the negative cable first before unplugging PCM.
Old Sep 10, 2009 | 11:55 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Nelson usually provides very well-detailed instructions with the pcm when he ships them out. Did you look at them?
Old Sep 11, 2009 | 11:14 PM
318BANDIT's Avatar
yea installed it dis mornin made a big difference n power and drivability im very well satisfied. i changen it out n 10minutes. iwill b usin nelson again
RustyD
May 23, 2016 07:04 PM
legerwn
56
Nov 15, 2015 10:21 PM
Cammed4ever
Sep 30, 2015 03:38 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
supershift67
Sep 18, 2015 08:21 PM
