computer
Find computer, loosen the two 7mm bolts in the harness (one per side) remove harness, remove PCM, install is the reverse of removal. Might not need the crank relearn, I didn't in my 02 (not sure if anything has changed).
PCM is probably what you wanted to search for to find the other threads like this one.
The PCM is located next to the battery and down a bit. You'll see it. However, Knowing what year your truck is would help as i think the 08+ models are in a different place.
legerwn
56
Nov 15, 2015 10:21 PM
Cammed4ever
Sep 30, 2015 03:38 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
supershift67
Sep 18, 2015 08:21 PM
