Compression Test Results
Old Apr 14, 2008 | 01:21 PM
beastolds455's Avatar
Exclamation Imho
Ive heard of guys running the engine in for 15-20 mins like ur builder says @
idle???? Me personally i would never do that on the count of u only get one shot at seating ur rings so on that note from my experiance i would run regular motor oil and break the engine in under load!!! when a engine is idling
the rings excert no force on the cylinders so they are just along for the
ride which is not a good thing because without load your not forcing the
rings out toward the cylinder walls under pressure which in turn causes the rings to seal in some places and leak in others because u dont have the rings
expanding evenly without load so first start-up after a rebuild is critical! get
in it and drive it. For example after I rebuild any engine I drive it under load
to about 50MPH for about the same amount of time as ur builder recommended the only diff. is im doing it under load and dont b afraid to
downshift it some as well this creates a vacuum in the cylinders to suck those
nasty metal shavings back into the crankcase. Try it see if ur numbers are alot higher as long as the machinist did his job correctly!
Old Apr 20, 2008 | 05:32 PM
moes04silverado's Avatar
Default Update
Well I got everything back together and put some miles in it - i think 60 or so. No codes or anything either...
Thing runs great - there is no hesitation or nothing. I plan on doing the oil change this week so I will re-check the compression and see what I've got. Oh BTW, 2 of those miles are 1/4 runs. I was not impressed with the times, but I am out of practice and I think the tune is a bit off....gotta call nelson on monday.
Old Apr 22, 2008 | 11:57 AM
FirstYrLS1Z's Avatar
What kinda times?
I had to work Saturday.
Next time you go,I need to go too.Hopefully I'll have the new larger slicks mounted by then to get me in the 12s'.
Old Apr 23, 2008 | 04:18 PM
Originally Posted by FirstYrLS1Z
What kinda times?
denny do you have any 16" radials that i can buy?
Old Apr 24, 2008 | 08:55 AM
No,I don't.Everything I have is 17".
But your question contains unanswered questions.
What kind of 16"s,regular passenger,performance,radial street slicks,non-radial strip slicks?
Old Apr 24, 2008 | 11:01 AM
something that i can us at the track...my 20" street tires just are not cutting it
Old Apr 24, 2008 | 11:48 AM
LS6_Silverado's Avatar
Default LS1 Compression check
Hey guys i just got a 36k ls1 long block i was about to do a compression check and i was wondering what numbers am i looking for? 175-185psi? Thanks for your help
Avalanche2002
Nov 30, 2015 07:31 AM
BlownHD
Oct 3, 2015 12:24 PM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
