Compression Test Results
These are the results of the compression test that I did yesterday for my lq4 swap. The lq4 for the most part is stock other than the cam...I replaced all the bearings and rings and these were the results.
1 - 175psi 2 - 180psi
3 - 187psi 4 - 180psi
5 - 185psi 6 - 185psi
7 - 162psi 8 - 160psi
I called my engine guy after i did the test and read him the results and he basically said if it was his motor he would run it. He wasnt real worried about the two low readings. He just said run it for 15-20 min at idle, drain the oil and then run it again on the road for 100 or so miles and recheck the compression after the second oil change and it should be better.
Anyone wanna share some imput?
