compression test numbers?
Old Jun 2, 2004 | 07:53 PM
dubrado's Avatar
Default compression test numbers?
going to do a compression check this weekend...and was wondering what the psi for the cylinders should be for a stock 01 5.3L
thanks!
Old Jun 2, 2004 | 07:56 PM
mudz5.3's Avatar
I say atleast 160-175 psi. How many miles?
Old Jun 2, 2004 | 08:06 PM
dubrado's Avatar
last owner said 14k
Old Jun 2, 2004 | 08:09 PM
mudz5.3's Avatar
eh, its a little on the low side to me but still manageable. Psi numbers on beamers are over 200 normally, lower mileage though.
Old Jun 2, 2004 | 08:27 PM
one03sierra's Avatar
Formerly one92rs
Talking
i think they are suppose to be near 125 to 140 psi. you will need to be worried more about them being less than 10% difference between cylinders.
Old Jun 2, 2004 | 08:45 PM
dubrado's Avatar
ya, i looked at some of the ls1 guys and they're numbers are higher, closer to 200 psi, I did some reading up and they said to just make sure the numbers are consistent and that the max variation between cylinders is no more than 30%
now I just need to cross my fingers and hope compression #'s are ok and pray that this motor doesn't have piston slap from hell
Old Jun 2, 2004 | 08:51 PM
Formerly one92rs
Talking
yes the ls1's will yield bigger numbers than our 5.3's will. 10% is a little low,i try to keep it at less than 20% varience.
Old Jun 2, 2004 | 09:30 PM
bigguy75inches's Avatar
around 130 ish is normal.. the factory service manual even has a formula for those cylinders that might be slightly normal.. i think take like your highest compression cylinder, lets say 130psi. then figure out like 20% of the highest. that number is 26. the lowest cylinder compression level should not be lower than 26psi than the highest. if so.. its considered ubnormal and should be fixed. if forget the EXACT percentage. but i know its close to 20% i think. if someone really needs this info.. i will try to dig up my manuals. and find it.
Old Jun 2, 2004 | 09:32 PM
opps, i totaly skipped your post 02 denali. what you said. lol
nabozny21
Oct 17, 2015 07:47 PM
KleanKustoms
Sep 30, 2015 05:07 PM
old motorhead
Sep 29, 2015 08:22 PM
Slammed silverado
Sep 28, 2015 06:14 PM
