compression?
Old Jan 21, 2003 | 09:01 PM
Texas Terminator's Avatar
11 Second Club
Default compression?
so what would my compression be on a 6.0 block with ls-1 heads? is that going to push up to 10:1 or more? i am force feeding my motor. will i need to get different heads or get the chambers milled?
Old Jan 21, 2003 | 09:30 PM
red53gmc's Avatar
Default Re: compression?
The 5.7 heads will raise your compression and do not flow as good as the 6.0 aluminum heads. I would stay with the 6.0 heads if you have the aluminum ones. If not, try to find some. The lower compression will be better for you anyways.
Old Jan 21, 2003 | 09:51 PM
BigTex's Avatar
Without running up the numbers, I'd say you'd be pretty close to 10:1. Not as good for boost.
walledition
Feb 24, 2026 03:27 PM
zblee
Nov 11, 2015 12:41 AM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
