Charging questions??
Old Dec 19, 2008 | 09:04 PM
GMCDee's Avatar
Default Charging questions??
My battery wont charge.... I went and bought a new ALT and put it on and my battery still wont charge its running off the battery and ive checked everything all wires are good and tight. Any ideas its got to be a wire or something electrical. Any help. Is there a fuse for the ALT??? I couldnt find one.
Old Dec 19, 2008 | 09:08 PM
ChevyTruck's Avatar
something else
You might have a dead battery, have you had it tested?
Old Dec 19, 2008 | 09:10 PM
GMCDee's Avatar
I havent but when i dissconnect my battery the truck will die,im not sure if these newer ones will run just off the ALT but i know the older ones will run off the ALT. And its a fairly new battery less then a year and havent ever ran it down.
Old Dec 19, 2008 | 09:14 PM
ChevyTruck's Avatar
something else
Which side are you dissconnecting?
Old Dec 19, 2008 | 09:16 PM
GMCDee's Avatar
+ side
Old Dec 19, 2008 | 09:30 PM
ChevyTruck's Avatar
something else
Have you done a voltage test on the battery?
Old Dec 19, 2008 | 09:31 PM
GMCDee's Avatar
Yea tested good 12.5 volts
Old Dec 19, 2008 | 09:38 PM
ChevyTruck's Avatar
something else
It is possiable that you have a bad ALT. Even know its new.
Old Dec 19, 2008 | 09:40 PM
GMCDee's Avatar
Its possible but its been tested. Im lost in the sauce
Old Dec 19, 2008 | 09:41 PM
ChevyTruck's Avatar
something else
Good luck with finding you problem, but I'm stomped
