cats cloged?
Old May 26, 2005 | 02:43 AM
5.3GMC's Avatar
Default cats cloged?
i think my cats are cloged? how can you tell if they are or not?
Old May 26, 2005 | 06:40 AM
quicksilverado's Avatar
Mine would drive fine until I went wot then it would loose power. It takes about 45 minutes to unbolt the y-pipe. Then you can pull it out and look at the cats.
Old May 26, 2005 | 09:58 AM
gonzo 6.2's Avatar
They make a pressure test gauge for testing restriction.Some muffler shops may have it.
Old May 26, 2005 | 10:18 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
If you have the stock y-pipe just unbolt it and take a look it takes all of about ten mintutes max to unbolt it. With the power you are making I would get some high flow ones anyway are just cut them off like you were talking about another thread.
Old May 26, 2005 | 11:20 AM
budhayes3's Avatar
PT's Slowest Truck
You can also use a vacuum guage hooked in to manifold vacuum. Run the engine in P or N and observe the guage (in P it should be steady...reading will depend on the size of your cam...anywhere from 16 to 21, 22 in/hg is normal). When you snap open the throttle vacuum will go down (0 at WOT). If you hold it around 2k it should stabilize a bit. What you need to check for is when you close the throttle after holding it at 2k...the vacuum guage should jump up to over 20 in/hg after you snap the throttle shut....if it creeps up slowly, you have an exhaust restriction.
Old May 26, 2005 | 06:02 PM
5.3GMC's Avatar
i have longtubes and i no ypipe. so i would have to cut em and check that way. if not i'll just go ahead and get high flow cats.
Old May 26, 2005 | 06:05 PM
5.3GMC's Avatar
is there any noticeable sound. cause when i go wot it sounds to me like when it shifts into 2 i belive. i don't know how to explain the sound.
Old May 26, 2005 | 11:21 PM
Mn Avalanche's Avatar
When my cats clogged.I could get detonation in the 5000 rpm range,and i had a no power in upper rpm range.My drivers side cat was the worst it would rattle at idle like popcorn seeds were inside.
madmann26
Apr 29, 2020 09:17 AM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
BlownHD
Oct 3, 2015 12:24 PM
Wolftrk99
Oct 2, 2015 08:17 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
