is this cam worth it?
Old Jun 28, 2012 | 11:08 PM
superslo04's Avatar
Default is this cam worth it?
i have a 2004 ext cab 4.8 im not looking for much just a little bit more power and be able to keep stock converter and drivability as it is my daily driver. my question is is this cam worth it? or can i go bigger? im not sure how to write out cam specs so heres the link
54-408-11 - XFI RPM Hydraulic Roller Camshafts
any help is much appriciated.
Old Jun 28, 2012 | 11:22 PM
jrmchevyman's Avatar
Would be noticeable over stock cam. With you being a 4.8L ext cab and the weight, also wanting to keep stock stall the 206/212 would work good. You might want to go 1 slight step bigger though on the intake side.
A 210/216 isky cam would be good, or a vinci 210/218. That would prob be about the biggest I would go IMO with your setup. Would be nice with at least a stock TB converter though which can be bought for cheap. Later on if you want more out of your setup, get a 278mm CircleD or FTI converter if you are on a budget.
Old Jun 28, 2012 | 11:36 PM
superslo04's Avatar
ok thanks for the info ill look into the other two before i decide. and with the tb converter is that something i can do in my garage or should i just have a shop do it? i have mechanical experience just never done it before.
Old Jun 29, 2012 | 12:07 AM
AndysC3's Avatar
I did my trans/TC swap in my driveway. Need a good sturdy jack, about 3' of 3/8 extensions. took me and two friends 12 hours start to finish.
Old Jun 29, 2012 | 12:16 AM
1FastBrick's Avatar
Custm2500's Rude Friend
The comp XR265HR low lift is also a popular choice for a fairly stock engine 212/218 522/529 with good results.
Part number is 54-412-11
Old Jul 10, 2012 | 07:10 PM
superslo04's Avatar
ok i decided on the XR265HR will that give me a nice lope? or sound stock still? and as far as the tb converter i found the 2800 stall one but it says its for the 4l65? is it the right one
Old Jul 10, 2012 | 07:20 PM
The TB converter is better than your stock truck torque converter, but depending on how much you can get it for, I would probably go with an FTI or CircleD 278mm such as a 3000-3200 converter. If you can basically get the tb converter for nothing then go for it, but you can get a 3200rpm FTI Street Brawler 278mm for $309.99 at jegs. Can't beat that price for the FTI, and its a reworked TB converter, that is stronger and stalls higher.
Old Jul 10, 2012 | 07:39 PM
superslo04's Avatar
well i found some on ebay for like 179 with free shipping
4L65E TRAILBLAZER 4.2 LITER 2800 STALL TORQUE CONVERTER | eBay
but 120 more and get a better one is a hard choice ill probably end up with the 3200 fti just because im still getting funds either way ill be happy. also what diameter pushrods? i saw a couple different ones looking on summits website i know the ls6 yellow springs are what most people use just not sure on rods.
Old Jul 10, 2012 | 07:47 PM
I'd get the FTI if it were me. As for the hardened pushrod length, most go for the stock 7.400 length. It doesn't hurt to get a $20 pushrod length checker for piece of mind though.
5/16" hardend pushrods is what you want btw.
Old Jul 10, 2012 | 09:21 PM
superslo04's Avatar
ok thanks i think i can afford everything in a couple paychecks im anxious to get everything but i dont wanna break stuff trying to put it all in lol
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Hmguyton
Aug 9, 2015 05:38 PM
Dirtywhite
Aug 5, 2015 04:10 PM
steves86ta
Jul 28, 2015 10:21 AM
sauldgold
Jul 23, 2015 02:15 PM
