Cam Swap From Hell Problems Continue
Old Jan 6, 2007 | 03:41 PM
  #51
well before you tune it, i'll race ya. lol
Old Jan 6, 2007 | 05:16 PM
  #52
Flyer's Avatar
Originally Posted by onebadrubi
Dirt isnt gonna spin that bearing that quick. I would think it would cause other problesm before spinning a bearing anyways.
Are you serious?
You realize the bearing tolerance on the cam is all of about the size of a **** hair, if any dirt got knocked into the top of the heads it drains right onto the lifters which goes right onto the cam which coincendently just happens to be right by the cam journals. A little spec of dirt can get in between the journal and bearing which creates friction between the two surfaces causing them to gauld and spin the bearing out of it oil journal. Please dont post if you dont know what you are talking about. Dirt spins bearings period, why do you think it is so pertanent to change the oil after doing any work on the motor?
Originally Posted by 1SLOW01z71
The reason I was an *** is because on multiple occasions when I post something he comes behind me and says something totally contrary to what Im saying and most of the time it is wrong.
I think you owe someone an apology for being, as you so well put it, an ***.
Old Jan 6, 2007 | 05:34 PM
  #53
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Just because that wasnt the case doesnt mean dirt doesnt spin bearings or that it can spin them by revving the motor like I did with no oil pressure. What I said was right on, just maybe should have worded it differently. I also said I needed to pull the cam to see what was going on that it may not be the cam.
Old Jan 6, 2007 | 05:47 PM
  #54
Flyer's Avatar
And all I said is that he deserved an apology for you attacking him like that and it still not being a cam bearing like he suggested it wasn't. Whether or not he gets one is all up to you. It really makes me no difference.
I have nothing else to say about the matter.
Old Jan 6, 2007 | 06:00 PM
  #55
1slow01Z71's Avatar
I shouldnt have been so "short" with him, I apologized and stated that I was in a foul mood due to all the problems, its not an excuse but is just how things are. Problem is solved and thanks to everyone who helped out.
Old Jan 6, 2007 | 06:27 PM
  #56
RandomHero's Avatar
02 PCM and bigger injectors here you come Mark
I already have an 02 pcm. I just need some bigger injectors, and to figure out how to tune this damn thing. You can really tell the exhaust is choking so I think I'm gonna do some headers with catless y-pipe next
Old Jan 6, 2007 | 06:45 PM
  #57
Flyer's Avatar
What size camis this?
I put a 216/220 114 in a stock 4.8 with a custom catback and a drop in K&N and noticed a BIG difference after tuning. The biggest thing was timing. It needed a few more degrees of timing to come alive and boy did it come alive then.
Old Jan 6, 2007 | 07:50 PM
  #58
budhayes3's Avatar
PT's Slowest Truck
Any 00 and up 4.8,5.3, or 6.0 injectors will work...check the classifieds, there's usually a full set for anywhere from $70-$100 (alot of guys have them left over from supercharger swaps)
Old Jan 6, 2007 | 07:51 PM
  #59
Flyer's Avatar
I have a couple of sets if your interested. PM me if you like.
Old Jan 6, 2007 | 08:33 PM
  #60
closet red neck's Avatar
Hell, I'll race him after the tune.LOL.
James
