Cam Swap From Hell Problems Continue
Old Jan 5, 2007 | 12:41 PM
  #31
if the oring were damaged it woul have very low oil psi, but it would still have pressure. I know that i had a cam bearing come out and it showed no oil psi at idle, but driving around it went up to 20 or so psi.
Old Jan 5, 2007 | 01:10 PM
  #32
RandomHero's Avatar
well I put in a new o-ring, oil pump, timing chain, I'm fixing to go put the last bit of stuff on and fire her up. Wish me luck....AGAIN
Old Jan 5, 2007 | 01:27 PM
  #33
good luck....again
Old Jan 5, 2007 | 01:31 PM
  #34
shupe's Avatar
Good Luck!!!!
Old Jan 5, 2007 | 01:37 PM
  #35
hourang's Avatar
good luck! i woulda changed the oil before starting her up. never know what gets knocked into the oil during the install.
Old Jan 5, 2007 | 03:00 PM
  #36
Good luck. To bad it didnt take just 3 hours like my first experience with cam swapping. LOL, J/K
Old Jan 5, 2007 | 03:54 PM
  #37
TURBHOE's Avatar
wow, what a hell of a cam change. good luck.
Old Jan 5, 2007 | 04:32 PM
  #38
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Welp, got everything buttoned up, EFI plugged in and still no oil pressure after turning it over for ~30 seconds with the coil packs unplugged and fuel pump relay pulled. We are going to pull a valve cover and see if we are getting oil coming through his pushrods. HIs intake is DIRTY thats why Im afraid of pulling it to swap senders. W e will see
Old Jan 5, 2007 | 04:57 PM
  #39
I'm actually excited to find out what's up with this. The oil pickup tube on LS motors bolts on right? No possible way to fall off.
I got $5 on sending unit or a pulled wire going to the sending unit.
  #40
How far down in Austin are you guys?
