Cam and Lifter question?
Old Nov 18, 2010 | 07:49 PM
LSJEEPandC5VETTE's Avatar
Default Cam and Lifter question?
Quick question, I am building a mild 5.3 and I am using a TSP 220 cam. What lifters should I use? Are the stock one fine or should I replace them? Also what springs are you guys running on otherwise stock heads? Thanks in advance.
Old Nov 18, 2010 | 07:53 PM
CashDudeHomie's Avatar
I have a 220 cam. I didn't change the lifters. I used a Patriot Gold double valve spring kit.
Old Nov 18, 2010 | 07:55 PM
budhayes3's Avatar
PT's Slowest Truck
If the engine is apart and on the stand, I'd put some new lifters in for some relatively cheap insurance. SDPC sells a complete set of LS7 lifters for about $120 I believe, there's a link to their website to the right>>>> As for springs, I'd go with some PAC 1218's, also available from SDPC or Texas Speed I'd get new lifter trays too, they're about $7 or $8 a piece x 4.
If you're just doing a cam swap in the truck, use the lifters that you have until they give you a problem...you have to pull the heads to replace the lifters.
Old Nov 18, 2010 | 07:59 PM
Motor is stripped down as it is, heads are in the machine shop atm. I thought they were alot more money than $120, for that price I may as well just bite the bullet and do it.
Old Nov 18, 2010 | 08:18 PM
budhayes3's Avatar
PT's Slowest Truck
$121.95 to be exact
http://sdparts.com/details/gm-perfor...parts/12499225
Old Nov 19, 2010 | 08:00 PM
Thanks for the info, what springs do you recomend for that cam as well? I know guys have been saying to stay away from comp.....
Old Nov 19, 2010 | 09:03 PM
budhayes3's Avatar
PT's Slowest Truck
I like the PAC 1218's...same specs as the Comp 918's without the history of breakages
(Check Texas Speed and SDPC for the PAC springs >>>>
Old Nov 20, 2010 | 09:39 AM
Preston129's Avatar
+1
PAC's are a great spring.
greedygenius
Sep 3, 2015 06:51 AM
Denali08
Aug 9, 2015 04:34 PM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
GRRR65GTO
Jul 10, 2015 08:27 PM
