California Exhaust Options
Old Aug 3, 2010 | 05:20 PM
cali92rs's Avatar
Default California Exhaust Options
Since I live in Califonia, I cant do long tubes, and I dont think shorties would do much more than the stockers (correct me if I am wrong).
What exhaust systems are you guys running that are Cali approved?
(When I say approved, I mean almost legal and should pass the visual).
FYI, right now I have a bone stock 05 crew cab.
In the future, I plan to do chip tune, CAI, MAYBE cam and MAYBE a 6-speed swap.
Old Aug 3, 2010 | 05:37 PM
RibeiroBJJ's Avatar
Praise The Lowered
I live in Ca and always have run LT headers with cats and a cam and have passed emmisions 3 times...I would say to either get a set of used TOG headers or Bassani new..Both are mid length and allow you to retain your stock cats..OR get a set of Pacesetter lt's with ory and weld you stock cats to the ory..should pass with a good tune....Good luck
Old Aug 3, 2010 | 05:54 PM
cali92rs's Avatar
PM sent
Old Aug 3, 2010 | 07:51 PM
006rcsb's Avatar
im in cali and i went with bassani mids, they use the stock y pipe, but you have to cut the pipe from the front of the cat off and weld on their flange, took the shop a half hour, and smog legal with the carb number.
Old Aug 3, 2010 | 11:06 PM
cali92rs's Avatar
Do you think the stock Y is a big restriction?
Old Aug 4, 2010 | 09:27 PM
KleenHall's Avatar
you cannot modify the cats in any way, its illegal to even replace a cat without notice of it being defective
aftermarket cats must be 50 state legal
headers must have a carb number
exhaust is pretty open, no real rules other than it must have a muffler, and meet certain db regs.
Old Aug 4, 2010 | 09:58 PM
RibeiroBJJ's Avatar
Praise The Lowered
Not for 90% of the board members..probably including you (the mods you mentioned)
Old Aug 4, 2010 | 10:15 PM
I run longtubes, an off road y-pipe. When it comes time to smog I'll weld some cats inti the y-pipe. The smells not to bad without cats.
ARC
57
Feb 21, 2022 10:54 AM
GXPJAY
Feb 13, 2022 08:15 AM
Corvette454l88
Sep 1, 2016 01:24 AM
FlowmasterMufflers
Aug 14, 2015 12:47 PM
Suburban2500
Jul 13, 2015 09:57 AM
