Buying Motor With Busted Intake
Old Oct 3, 2006 | 04:23 PM
benvortec's Avatar
Default Buying Motor With Busted Intake
I was looking at a motor that came out of a wrecked silverado that was hit high and busted the upper intake manifold. What could be worst case for this motor? (What could this have done to the rest of the motor)? Does this sound like a bad idea?
Old Oct 3, 2006 | 04:41 PM
vanillagorilla's Avatar
The threads could be striped out on the heads, where the manifold bolts to at best. At worst, some rods caps could've come loose and scarred up the crank. It happens to circle track cars when they smack the wall hard enough. If you're sure the truck didn't hit a stationary object head on, then it's probably fine. I would at least pull the pan though to make sure.
Old Oct 3, 2006 | 04:56 PM
LesPaul's Avatar
my bet would be your fine.... i would check to make sure no peices from the intake fell into the head and stuff like that.... BTW if you need a new intake i have one in perfect condition if you need it
Old Oct 3, 2006 | 09:40 PM
benvortec's Avatar
thanks man! i'll let ya know!
Old Oct 4, 2006 | 08:06 AM
Quik's Avatar
5 year bitches!
this is my motor out of a donor truck and runs fine and good so you be the judge
Old Oct 4, 2006 | 01:59 PM
jakebdb56's Avatar
damn that SS was pretty messed up
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
The_W
Oct 28, 2015 09:00 PM
justuc
Jul 24, 2015 11:52 PM
04450r
Jul 24, 2015 01:58 AM
